Where do you guys run your main feed line?
Just wondering where you guys have your main feed lines routed. I have my bottle in the spare tire compatment with the line going straight down through the floor pan, over the RR wheel well and run along the bottom of the car tucked up on the inside of the body pinch weld, behind a heat shield on the firewall and up and over the back of the motor to my plate. Im curious to know if anyone runs them inside the car and through the perfectly placed hole and grommet behind the glove box.
[QUOTE=jeepers_88;11618654]Just wondering where you guys have your main feed lines routed. I have my bottle in the spare tire compatment with the line going straight down through the floor pan, over the RR wheel well and run along the bottom of the car tucked up on the inside of the body pinch weld, behind a heat shield on the firewall and up and over the back of the motor to my plate. Im curious to know if anyone runs them inside the car and through the perfectly placed hole and grommet behind the glove box.[/QUOTE]
Thats the way mine is.
I guess I'm the oddball, Mines half legal
My bottles mounted on the drivers side trunk space (replaced the stock CD changer) with the line ran underneath the panels/carpet out the gromet under the drivers seat. Tucked up nice under a heat shield to my noid under the radiator support bracket.
I'm sure someones wondering why I mounted it on that side. I just really wanted to keep the spare tire for that one time I'd need it. As far as routing the main line like i did, the line wouldnt be long enough had i gone out the gromet under the spare tire then up towards the engine bay.
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
