How to bypass pressure transducer on NX bottle heater kit?
I'm low on cash right now and don't want to buy a replacement adjustable transducer from dynotune. My NX one sucks. It wont kick back on untill the pressure drops below 900psi.
Anyone have an idea how to bypass the transducer and run it manually
Im this close to just buying a HSW or Dynotune heater package this NX one is slow as ****...
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Ripped](https://ls1tech.com/forums/images/smilies3/ripped.gif)
The NX element will work fine. Just get rid of that Pressure switch. I hated them as well. You may want to upgrade to our pressure switch. It has closer tolerences and is adjustable.
http://www.nitrousoutlet.com/catalog...product_id=992
Or you can just take the two wires that connect on to the pressure switch and connect them together. This will bypass the pressure switch.
If you decide to switch heaters all together check out our Billet Bottle bracket/heater combo or our Brand X black heater. They both will out perform the NX heater all the way around.
Dave
Dave
Yea I was running dual NX heaters prior to going NANO, and they are a little slower no doubt than most on the market. However, this isn't all bad news, the smaller amp draw was a plus for me going dual heaters and the reason i went with the NX heaters. I also tried the mech transducer, as well as the temp based transducers, but none performed as well as manual. wire it as dave said and all will be fine, as long as you keep an eye on things so pressure doesn't get to high. also, be sure to have it wired through ignition so it will auto shut-off anytime the car is off. NANO is much, much better than heaters. heaters have become dated technology, IMO.
Robert
Robert
