Nitrous Noob Checking In
Old Jun 3, 2009 | 05:53 PM
SkullV's Avatar
Default Nitrous Noob Checking In
Well guys I just ordered the HSW LS6 Dry Plate kit and their All Out Nitrous Accessory Kit. This is my first experience with nitrous and I will be monitoring the A/f with an Innovate LC-1 wideband controller and injectors with HPtuners. If there is anything else I should know before I dive in PLEASE let me know!
Old Jun 3, 2009 | 07:43 PM
JScamaro's Avatar
Depending on how big of a shot you run, you may need to upgrade your injectors/fuel pump especially with the dry shot (injectors).
Old Jun 3, 2009 | 09:57 PM
SkullV's Avatar
I am going to be running a 100 shot. I plan to get it on the dyno and start with a 50 shot, then 75, then 100 just to make sure the injectors aren't maxing out and the a/f is ok.
Old Jun 3, 2009 | 11:02 PM
SkullV's Avatar
Does anyone know what my stock pump/injectors should be able to handle? I can do a log tomorrow but if anyone knows off the top of their head that would be great!
Old Jun 3, 2009 | 11:38 PM
SkullV's Avatar
Now I am second guessing myself about the wet vs. dry argument. I will talk with Nick at HSW tomorrow and order the kit that is right for my application.
Old Jun 4, 2009 | 12:02 PM
purdueranger's Avatar
You are going to want injectors if you want to stick with the dry shot. Now if you wanted wet then you can get away with your stock injectors but I would upgrade your fuel pump to be on the safe side.
You know how well my kit works.
Old Jun 4, 2009 | 01:39 PM
SkullV's Avatar
I ended up getting the wet kit...should be ok on the stock fuel pump for a 100 shot
