Need help added 100hp no et gain.
Old Jun 20, 2009 | 07:59 PM
n20stroker's Avatar
Default Need help added 100hp no et gain.
Hey guys want to see if anyone could help me out? Runnin a 200 shot direct port on my 454 through a th400 w/a Circle D 3300 stall converter. Car runs 9.23s at 148 with 1.3xx 60ft. Just added a 2nd stage (100 shot) and didnt gain any et or mph across the boards. I footbrake it to 2500 the 100 comes on at wot and the 200 is on a 1.2 sec delay. Just would like to see if anyone has any input that could help me out
Thanks
Old Jun 20, 2009 | 08:14 PM
awd2rwd's Avatar
are you sure everything actually worked haha??
Old Jun 20, 2009 | 08:20 PM
n20stroker's Avatar
Went back to the pit and went over everything. act Wot swich and checked each staged one at a time sol working.
Old Jun 22, 2009 | 08:34 AM
Noyzee's Avatar
8 second mod
sounds like it isnt working. could be a amp draw issue or something.
i would turn the 2nd stage off, see if the 1st stage improves et/mph over your motor pass.
what do you have activating your stages?
Old Jun 22, 2009 | 09:05 AM
ATVracr's Avatar
X2.
You should do that anyway to make sure your 100 shot tune up is good before you start stacking the kits.
Old Jun 22, 2009 | 09:20 AM
thechef's Avatar
Moderator
yea sounds like it isnt hitting, go back and go over EVERYTHING its always something stupid when it doesnt work
Old Jun 22, 2009 | 10:36 AM
Noyzee's Avatar
8 second mod
Originally Posted by ATVracr
X2.
very true, i always did that, and with 1 stage, i start small 100-150
Old Jun 22, 2009 | 10:38 AM
moehorsepower's Avatar
Did you check your bottles to see if you used any more nitrous than usual?
