bottle mounting question
the line runs under the console right there at the back, and up to the engine bay...I mounted a autometer N2O gauge in my cupholder with a peice of aluminum around it...
The little boot on the blowdown was on it when i bought it...????
Originally Posted by angst911
cool... where did you go through the body to get into the engine bay? I think that's more what I was asking when I said where did you run the line.....
I'm guessing that's where he ran the N20 line.
JxxxOxxxE, looks good. Nice braket spacers. Is that a 10lb bottle under that? You said NX right?
If you use the 5177 kit you must cut the lower part of the larger bottle braket between the 2 mounting holes and bend them facing straight down. Then drill 2 new holes in order to mount to the tunnel. If I had to do again, I'd do it like JxxxOxxxE's
its a 10 lb bottle with the regular brackets that came with the TNT kit. Ones kinda tall, the other is short. I still had to use the spacers though...There is a NOS heater on it too...
Believe it or not, it does make an extremely good arm rest in the back...Hell my brother fell asleep on it on a trip to texas...and the whole reason for mounting it there was for the ease of opening it...
