nitrous solenoid problem!
Old Jul 19, 2009 | 01:44 PM
superfox's Avatar
Default nitrous solenoid problem!
guys ,
i have nitrous solenoid problem not work , all wiring work good fuel Solenoid work , i check all hose fitting are good , i test the nitrous solenoid when the bottle off nitrous solenoid (empty nitrous line) work ! if i open the bottle its dosent work , any one have same proplem ?
Old Jul 19, 2009 | 02:17 PM
deathbydisplacement's Avatar
not being a d!ck but i cant understand what your saying.Read over your message before you post.
Old Jul 19, 2009 | 02:18 PM
SkullV's Avatar
So you are saying that your nitrous solenoid works fine unless it is under pressure from the nitrous?
Old Jul 19, 2009 | 02:22 PM
If the solenoid is not working under pressure it would lead me to believe its a bad solinoid and needs to be replaced or rebuilt.
Old Jul 19, 2009 | 02:58 PM
superfox's Avatar
sorry guys i didnt speak english well i speak 4 language ,yes this is the proplem , i change 2 nitrous solenoid same problem i have ZEX and the HSW
Old Jul 19, 2009 | 04:45 PM
SkullV's Avatar
What is your bottle pressure when the problem occurs?
Old Jul 19, 2009 | 05:11 PM
superfox's Avatar
now the bottle at 1300psi , if i close the bottle and make the hose leak to disconnect or remove the bottle solenoid spray nitrous !
Old Jul 19, 2009 | 05:57 PM
PONTIAC SLP's Avatar
i have the same issue , what nitrous noid u have ?
Old Jul 19, 2009 | 06:06 PM
superfox's Avatar
Zex & hsw
Old Jul 19, 2009 | 06:27 PM
how old is the solenoid?
Old Jul 19, 2009 | 07:02 PM
cbra-klla's Avatar
Solenoids won't usually open under that much pressure. Get the bottle pressure between 900-1000 psi. Its not good trying to run that much pressure
Old Jul 19, 2009 | 07:34 PM
i Agree^^^ they will most the time open if there not getting weak but this will cause premature wear on the solenoid
Old Jul 19, 2009 | 08:27 PM
cbra-klla's Avatar
Yep. I sprayed an lt1 back when I was 16 years old, had over 1400 psi. Didn't know any better. If I had it probably would have blew up. Great screename by the way!!!!!
Old Jul 19, 2009 | 09:21 PM
SkullV's Avatar
The HSW kits are supposed to be used at 950 PSI. 1300 is very high and is pretty bad to have that kind of pressure sitting on a solenoid plunger.
Old Jul 19, 2009 | 10:55 PM
jmill96Z's Avatar
Lower the pressure to 950, and it will work like a champ. There is no advantage to running crazy pressure. Especially anything more than 1150 which is the point which it changes from a liquid to gas form
Old Jul 19, 2009 | 11:45 PM
superfox's Avatar
i will try when i back to home
thanks guyssss
Old Jul 20, 2009 | 01:36 PM
superfox's Avatar
i low the bottle pressure the to 950 PSI its work fine , thanks guys
Old Jul 20, 2009 | 09:44 PM
no problem
