NITROUS ? on Vic Jr.
-Chris
Robert
http://www.nitrousoutlet.com/catalog...roduct_id=1395
You can do what you are wanting to with the spray bars without a problem. People have been using plates to spray 300+ hp for years now without a problem.
-Chris
Robert
I mean look at your old elbow Robert. That thing is rediculous. Were they trying for a venturi effect when they designed that thing? LOL Doesn't work like that guys.
OP-- Get that pro flow kit that the guy is selling on PT. Then piece together a bottle and feed line. You will come in way cheaper, and have a proven setup without having to send your intake in, pay shipping both ways, and permenantly modify your intake.
That's the one we're talking about. They are awesome for boost. But that is the elbow people are removing to go with the 4150 and make all of the power gains. There are different edelbrock designs. The really low profile one does suck, but look at Roberts. That has a little better flow pattern into the plenum.
I have done a lil research and that pro flow kit seems like a good starter setup. i have a buddy that has a bottle and lines i can grab from him..
You will love that plate.
What size is he regulated to?
Here's what the real break through is, and was done on the computer and then flogged for many thousands of hours to find something that worked on the LSx specifically. I also added the spacer in part to get a better more even flow (pulse) and more top end.
By the way, the reason you see sheet metal intakes like you do, is because they were the only game in town for some time. when i got started with the single plain the sheet metal was the only chance of running a hood. But now there are other players coming in to the lsx game with big deeeeep pockets IE: Edelbrock. look at the last picture, you really think that would out perform the Edelbrock on a high HP set-up?
Robert
you are saying that edelbrock elbows suck and that an intake elbow from intakeelbows.com with a *insert the mm throttle body of your choice here* is on par with a straight 4150 throttle body?
I want whatever this guy is smoking!!!
and you are correct, the inside of the edelbrock intake elbow is rough, and it is there to cause drag. but that drag is there for a reason. it's called a laminar boundary layer of air. A smooth surface will promote a layer of air that flows right above the surface of the intake. This is great, if your intake is straight (i.e. single plane). but it's actually bad if you have any curved areas (i.e. an intake elbow). the curve in the elbow disrupts this airflow layer and creates turbulance, more than the "rough edges" of the edelbrock intake elbow.
The rough edges on the edelbrock intake, although create a little drag, doesn't promote this layer of airflow, which offsets the drag made by those cursed "rough edges," which all goes back to my original post of "edelbrock has a little bit of r&d in their elbows". Riddle me this. Ever play golf or attempt to play it? Ever look at the actual golf ball? Ever wonder why there are little dimples all over the ball? Ponder that for a moment.
and i don't really think I know anyone that uses an ultra low elbow either. that's geared more towards vette owners imo. most people get the low profile one with a vic. jr and do a little cutting. or just run a gmpp intake w/ a low profile one and don't cut.
and a 90 mm throttle body flows 1100 cfm
a fast 4150 tb flows 1375 cfm
I mean come on... easy math there. I don't want to break it down any further for you.
