How much timeing do i need to pull??please help
id personally put a ngk 7 non projected plug in it and start around 20 degrees of timing and go from there. ofcourse that is my personal opinion and would feel comfortable starting there.
good luck.
good luck.
get rid of the TR6's for some 7's.... run some good fuel and i'd say pull 7 degrees to be safe..... 2 degrees per 50 hp plus 1 till you get a good read on the timing marks on the plug....
but get rid of the TR6's...
Wow the TR-6s are that bad???Why the TR-7s?And is that -2deg per N20 HP(shot)??Thank you guys for helping.I belong to another forum(not going to say there name) and all they do is complain if i dont search,or get cocky.So once agine thank you for your help
Robert
Wow thats alot for a 150 shot.This is my DD so i think i will keep it at 125 with tr-6,lingenfelter pump,and some 42#injectors.Thank you guys for all your help.You have all been a awsome.
