Harlan switch not working
Old Nov 25, 2003 | 08:45 AM
next's Avatar
Default Harlan switch not working
I've got my window switch wired to the ground side of the FPSS. I've programmed it for 4 cylinder mode and set the on/off. When testing it, I get a brief hit, then nothing. After that it won't work at all. If I bypass it, everything works fine. Are you supposed to set it to coil per plug after you program it????
Anybody else have a similiar problem?
Old Nov 25, 2003 | 12:02 PM
slow's Avatar
you have this on the coil to the relay right, (pins 86 or 85) not on the high current wires to the selonoids? (pins 30 or 87)
Ryan
Old Nov 25, 2003 | 03:18 PM
next's Avatar
The FPSS is run from the relay (86 pin). Then I ran the white window switch lead to the ground side of the FPSS. Now I thought when I reached my lower rpm program it would ground the circuit and voila. But unfortunately... still scratching my head.
Old Nov 25, 2003 | 04:52 PM
99TranTrany's Avatar
TTT I need help hooking this thing up as well. So the white wire is suposed to go to a ground. So I guess you could use the WOT switch ground as well? Mabye you should try hooking it up there next, NEXT
Old Nov 25, 2003 | 05:00 PM
next's Avatar
If I understand this right (which mine isn't working!), the white wire from the harlan switch ties the harlan into the relay circuit. So it's not the ground, but the reason I tied into the ground side of the FPSS was to tap the relay circuit. I am considering the WOT if I can't get any other help.
Old Nov 25, 2003 | 05:11 PM
Where is it suposed to tie into the relay? It says in the instrutions not to directly connect the wire to the solinoinds or extrnal lights, only to wire it to a relay, if you did so it might fry the window switch. So should we connect it as the ground for the relay? It is suposed to supply a 12V ground durring the window of opperation? I dunno what do you think?
,Justin
Old Nov 25, 2003 | 07:11 PM
slow's Avatar
there should only be 1 ground location that you can install it. You want it to end the low current control loop, should be similar to this:
Arm +12 -------relay------wot-------fpss------ window(ground).
provided the WOT, and FPSS are switched on the circuit is just waiting for the window switch to provide the ground.
(note, all the switches and relay, can be in any order as long as you have a +12 for the arm, and the window switch providing the ground)
Is this similar to how you have it wired, i thought it was, but the comment "I am considering the WOT if I can't get any other help."
Ryan.
Old Nov 25, 2003 | 07:32 PM
next's Avatar
Ryan.
Yup, that's how it's wired. The relay circuit 2 sides - one to the WOT and one to the FPSS. Then to tap into that circuit by adding in the window via the ground output on the FPSS (the window switch is now providing the ground).
I said I'm considering changing the wiring to the WOT side just out of hope that there's nothing wrong with my window switch. Can't I hope for some old fashion fued between components and by separating them all will be well again
Old Nov 25, 2003 | 07:46 PM
slow's Avatar
there is no ground side of the wot or the fpss, they are just 2 contact switches.
you need +12 to one side of the relay, and ground to the other.
if the harlan will provide a ground, it does not matter where the other switches are. Verify that it does provide a ground, by removing the other switches temporaily, and see if the relay will click when you give it gas. (if you don't have a multimeter.)
of course disconnect the output, so no n20/fuel goes into your motor.
Ryan
