nitrous ?
Old Aug 28, 2009 | 11:02 PM
01zb4c's Avatar
Default nitrous ?
Ok so i just finshed all my nitrous up and didnt work like it should.... I have an 01 z28, nos brand plate with .052/f and .032/n jets round 100 shot what the speed shop told me to run... hsw mircoedge, trigger set to wot voltage and sparying between 3000 and 5400.. purged tell its white... everything works fine and mircoedge gos from standby, armed ,to spray... now the headaches start, punch it and takes off and when it sparys it falls on its nuts, pops, and bogs way down.. and i just let out and slow back down, check everything over and go again, did it the same thing over and over bout five times....
any input or questions would be a great help thanks
Old Aug 29, 2009 | 01:01 AM
itSSlowZ28's Avatar
you definately have your jets backwards causing it to run very rich. would explain the bogging and popping
Old Aug 29, 2009 | 01:13 AM
01zb4c's Avatar
No your bigger jet is the fuel...
Old Aug 29, 2009 | 10:35 AM
1badA3Z's Avatar
I too think you have the jets backwards,i used to run a plate like you have,u should have 52n and 32f,ur car is pig rich with them reversed,swap them and i bet it runs like a top!!
Old Aug 29, 2009 | 10:56 AM
Powerhouse's Avatar
They're backwards. Swap them around.
Old Aug 29, 2009 | 12:08 PM
01zb4c's Avatar
ok guys ill give that a try thanks ill keep u updated
Old Aug 29, 2009 | 01:43 PM
w3s1c0a5t's Avatar
That cure it?
Old Aug 29, 2009 | 01:59 PM
MelScrilla's Avatar
Im curious to here the results also?
Old Aug 29, 2009 | 02:31 PM
Powerhouse's Avatar
He's probably out having fun lol
Old Aug 29, 2009 | 09:44 PM
01zb4c's Avatar
thanks for the help guys, that fixed.... runs like a dream now... night and day different. thanks again
Old Aug 30, 2009 | 12:35 AM
itSSlowZ28's Avatar
good to hear. glad to have helped
