TR7 plug right for me?
Old Sep 1, 2009 | 08:55 PM
MYSTIC-1SC's Avatar
Default TR7 plug right for me?
the mods i have are in my sig. I currently run the ngk tr6 gapped at .037. is this ok for my mods or should go ahead and go a step colder to the tr7. O and also what gap recommendations for this plug. Car has bolt ons ms3 cam and 125shot, but i plan on steping up to 150 sometime soon. Let me know what you guys think.
thanks.
Old Sep 1, 2009 | 10:13 PM
INTENESS's Avatar
How much timing do you have pulled for the nitrious?
Old Sep 2, 2009 | 09:03 AM
MYSTIC-1SC's Avatar
i would have to check with my tuner.
Old Sep 2, 2009 | 11:01 AM
ShiznityZ28's Avatar
Don't run the tr-6 at least get the 6 range non projected. Id put a 7 in when you go to the 150 but the tunner will probably have to mess with idle and drivability to get the 7's happy. they need to be run leaner and more timming to keep heat in them to not foul out.
Old Sep 2, 2009 | 08:28 PM
MYSTIC-1SC's Avatar
thanks for the advice anyone else?
Old Sep 3, 2009 | 08:34 AM
dkbmxer002's Avatar
I ran a tr6 with long tubes, stall, lid and cut out with a 125 shot for 30k miles with a **** ton of nitrous ran through the car and no issues.
Old Sep 5, 2009 | 02:49 PM
MYSTIC-1SC's Avatar
well, i was just trying to see how safe it was with a cam as well.
Old Sep 5, 2009 | 04:20 PM
conde'strans's Avatar
I find myself in the same position as you and havn't made up my mind cuz of the mixture of opinions on this subject!
Old Sep 5, 2009 | 05:50 PM
INTENESS's Avatar
Go with the TR7 plug you will sacfrice a little na hp,but it will be alot safer 150 shot.Better to be on the safe side also pull a plug right after a run on the bottle see what it looks like.
Old Sep 5, 2009 | 07:00 PM
And what exactly should u look for on it(just wondering)?
Old Sep 5, 2009 | 07:59 PM
INTENESS's Avatar
If its lean the tip is going to be whitesh,if you get detonation its gong to have a speckled look on the porcealean part of the plug or the tip of the plug could be damaged.If your running rich it will be black or soaked with fuel.you want the tip of the plug to have brown tannish color to it and have the timming mark end right at the bend of the tip of the plug im not a expert but this is what iv'e been told.The best way to really check a plug is to cut off the threads of the plug right after bottle pass and look then.
Old Sep 5, 2009 | 11:53 PM
Caribe's Avatar
I went from the NGK Tr-6 to the NGK BR7EF (stock number 3346) without any tuning. Car idles and drives the same.
Old Sep 6, 2009 | 10:15 AM
ATVracr's Avatar
Someone needs to dyno a TR6 and the Br7 I bet there is no hp difference N/A.
Old Sep 6, 2009 | 10:29 AM
streetassasin's Avatar
Im going to go with the br7ef on a heads, cam 150 shot car
Old Sep 6, 2009 | 01:12 PM
I've heard there's some hp sacrificed N/A with them. Any proven results of this?
Old Sep 6, 2009 | 04:30 PM
ATVracr's Avatar
I heard there was none.
Old Sep 7, 2009 | 05:30 AM
Robert56's Avatar
I don't think there really is a measurable amount of HP difference 6 to 7. I have been running the 7 for some time as a street/strip plug and no real issues. i can tell you for certain that a 7 will not last as long as a 6 on the street. As stated, great for a 150/185hp street/strip shot, IMO. the Br8 is only 1/2 a point colder than the 7, IIRC, so a great street/strip 185/200hp shot plug, again, IMO. After 200, you should be getting real serious with your tuning skills because the cylinder pressures are really starting to play strong on your motor. To be clear, I am talking mild cars, not 14.3:1 compression 150/200hp shot motors, lol.
Robert
Old Sep 7, 2009 | 08:43 AM
WS6 Canada's Avatar
BR7EF gapped to .30
Old Sep 7, 2009 | 09:03 AM
gillbot's Avatar
I just put BR7EF's on my cammed car, gonna add a 100-150 shot soon. Gapped at .28 or so.
Old Sep 7, 2009 | 09:50 AM
JAX04's Avatar
i run ngk BR7EF gapped at .035. no problems, i may have noticed a slight, VERY SLIGHT, decrease in performance. i have had them in for about 3k miles, and knock on wood, have had no problems.
im on a stock tune 04 gto sprayin 100 shot wet.
