hesitation in the kit
Old Sep 7, 2009 | 01:37 PM
w3s1c0a5t's Avatar
Default hesitation in the kit
We got my nx kit hooked up the other day. I noticed there is some odd lag in it.
I put it in neutral got it in the window and wrapped it a few times just to get the air out.
After that I still need to make close to a full pass before the kit hits right.
The way it feels on the first couple of hits is it flashes the converter and then actually drops rpm then starts pulling but not like it should.
After that the car seems to come alive and its runs hard after the shenanigans.
Any ideas?
Old Sep 7, 2009 | 10:22 PM
Soul Crusher's Avatar
fuel gets to the nozzle/plate before the nitrous does?
Old Sep 8, 2009 | 09:41 AM
Nick@HSW's Avatar
Any ideas?
What pump are you running and what other mods do you have? What about line size and length from solenoid to nozzle? And are you running any type of window switch/controller?
Nick
Old Sep 8, 2009 | 07:50 PM
w3s1c0a5t's Avatar
Stock pump. Nx window switch.
Idk guys it wierd It also feels like it hits and then like it just isnt spraying consistent.
And i have to hit it several times and i never get the same "feel"
Old Sep 9, 2009 | 08:15 AM
ty_ty13's Avatar
7 Second Club
bottle pressure?
Old Sep 9, 2009 | 10:03 AM
TARZAN's Avatar
Do you have a fuel pressure safety switch?
-Will
Old Sep 11, 2009 | 12:06 AM
w3s1c0a5t's Avatar
Bottle pressure was at 1200 psi. Good as can be.
Nope no fpss. I have no idea whats up. Sometimes it even pulses?!?
Idk but i wish you guys would fix it...
Old Sep 11, 2009 | 01:18 AM
BAAAAAH's Avatar
not trying to be "that guy"... but who did the install and did they know what they were doing?
Old Sep 11, 2009 | 02:12 PM
w3s1c0a5t's Avatar
Me you and some silly cobra owner..
So not really.
Old Sep 11, 2009 | 02:24 PM
BAAAAAH's Avatar
figuring anything out? we should go to the grove and work on it again...
Old Sep 11, 2009 | 03:03 PM
toretto's Avatar
Did you use the built in TPS switch in the box?
IF so, try setting it up so that it activates @ 3/4 throttle.
Old Sep 11, 2009 | 03:07 PM
BAAAAAH's Avatar
nope....we didnt use the TPS. we just used a WOT microswitch.
Old Sep 11, 2009 | 03:55 PM
Robert56's Avatar
I kind of take the same path as Nick. You may have a fuel supply issue (not to confused with capacity issue), because if it eventually catches up and runs ok, I would look there as a begining point. Try adding a hot-wire kit to ensure you get the best voltage possible and this can help up to 20% 9you can easily make one up at home and save $$). Check fuel filer. Depending on controller, some have delay that you could set to allow the fuel to start before the spray. It sounds like something basic, just keep picking at it like you are and it will come together. You didn't state, but I suspect that you are pulling off the rail? This is a very common problem for wet hits pulling off the rail and one of the reasons many go to a stand alone fuel system.
Robert
Old Sep 11, 2009 | 04:36 PM
TARZAN's Avatar
Use an inline accessory port fitting and a manual pressure gauge. Monitor the fuel pressure for a pass.
-Will
