Getting There.... Finally in the 9's
Back story--tune on stock PCM was completely jacked after switching over to the 4150 TB, Vic Jr and direct port setup. After getting the run around from a couple "reputable" LS tuners, I decided to jump on a deal to go with BS3.
I started with the motor tune on Saturday. Made good ground, and had a solid tune running 12.0's on motor with 12.7 AFR and 28 degrees of timing.
Sunday:
100 shot ended up being 10.68 @ 125 not great, but it felt good to go quick again.
Decided to hit the full shot with a 2.5 sec. delay. The car launched horribly, but trapped 140
Not a bad way to end the dayFinally today--
I made some chassis adjustment, and loosened the front shock up a little. Car went 9.92, 9.81, and finally
R/T: .3190
60ft: 1.33
330: 3.9668
594ft: 5.7889
1/8 mile: 6.1929 @111.37
1/4 mile: 9.7420 @ 136.84
I had to peddle, and had a little mis-shift. Basically it's been a while since I've launched like that so I short shifted, and was caught by suprise.
All-in-all, not too bad for the first real time out with the combo, and having an amateur tune.
Thanks to everyone that helped me out through all of this BS. The car has more in it, and if I can find some more nitrous without having to buy a whole mother bottle, I'll be out there again with better air.
These little motors are a lot of fun. Def. keeps the cost down where I am at right now.
How do you like your PTC converter? would you reccomend them?
Congrats on starting to getting it sorted out. A 1.33 sixty off of the foot brake is nice.
Most of that bouncing was driver error. I peddled, then had a self inflicted shift error. Just didn't think I had that kind of tune up in it. Really caught me off guard.
