Dual Stage: Plate on top of progressive money maker - analyze my setup please!
I want to do a dual stage setup on my car, looking for some of you nitrous experts to give it a once over.
First I want to do a progressive 50 shot on a NitrousOutlet money maker kit. My thought process is that with the money maker 100% hidden and progressive, no one will ever know that it exists.
I want to spray on top of that a 100 plate. This will be obvious, noids mounted out in the open, etc.
Are there issues spraying a plate kit on top of a progressive. They would both be wet, and both share the same window switch (probably an FJO).
The setup will have two 10lb bottles, however I need to have it able to run off of one single 10lb bottle. So that if I am nice enough to "remove my bottle" I still have one bottle left to run at least the moneymaker. Is there anyway to feed one bottle into another rather than feeding both into a Y and then to the noids?
I am thinking I can run the n20 to the moneymaker noid then to the plate kit noid and purge there. Any issues with the supply? I want to run it with one purge.
I want to tap into the fuel supply line for the money maker under the car, running a walboro 255 pump (car makes 450 RWHP N/A). I'm curious if I'm going to be fighting lean spike issues.
I am sure I am missing something, but that should cover it for now.
Because its fairly obvious when a car "without a bottle" picks up an extra 150 horsepower, even if it is on a progressive.
It would also be obvious when the times on the 150 plate were very similar to the times on the 150 progressive.
dude, either way, when you spray it shows. I think your best bet is run 75-100 through the MM and put a 50 in the regular kit, and run guys on the bottle but offer to show them the jets.
check PM's
check PM's
