Replacement for rubber bellows
Old Sep 22, 2009 | 07:22 PM
TA1364's Avatar
Default Replacement for rubber bellows
I was trying to mount my nozzle tonight and to make it short I need a new bellow. Dont think duct tape is going to cover the extra hole very long LOL. I dont want to spend $62 on a slp, what are my options?
Old Sep 22, 2009 | 07:38 PM
jmill96Z's Avatar
Go to your local hardware store and head for the plumbing section. Look for Fernco. $5 fix
Old Sep 22, 2009 | 08:16 PM
SlvrFormula's Avatar
This easiest thing to do
Old Sep 23, 2009 | 07:31 PM
YURVIEW's Avatar
if you can't find that... Ebay has some for around $32. I have one on my car. works fine. altho needed to trim (shorten ends) to fit with my 90TB. the Diameter is correct size for 90mm
Old Sep 24, 2009 | 03:49 PM
Chris@NitroDaves
Guest
Posts: n/a
This might help
http://www.siliconeintakes.com/index...69f93445561ded
Old Sep 25, 2009 | 01:37 PM
TA1364's Avatar
Got this fixed, PITA to get on the throttle body tho. Had to to grind the hell out of the inside with the dremel but I got it to work. Nice $7 fix.
Old Sep 25, 2009 | 02:53 PM
jmill96Z's Avatar
If you had asked, I would have told you to boil it, then put it on while it's hot. Makes it a little more pliable.
Old Sep 25, 2009 | 06:53 PM
gillbot's Avatar
fernco at lowes, if you go to the one in huber, they'll let you take a handfull of different sizes out to see what will fit. That's what I did.
I got one of the Y ones, and I cut the Y leg off sonce it had a slight bent in it already. It made the fit much better than the typical straight piece.
Old Sep 30, 2009 | 01:52 PM
wantmore's Avatar
Originally Posted by Chris@NitroDaves
What intake elbow would you suggest from these people? They got a bunch...
Old Sep 30, 2009 | 04:25 PM
Chris@NitroDaves
Guest
Posts: n/a
It really depends on your setup....78mm or 90mm TB------78mm or bigger MAFF------Is the connection going to be straight or is there a slight bend that is needed....... there are more than several different combos that can be used.
Old Oct 1, 2009 | 08:19 AM
wantmore's Avatar
Chris
I have a stock TB and have a Fernco on there now going to a SLP lid. Fernco just looks bootleg...
