Looking for some nitrous suggestions/advise
Old Oct 11, 2009 | 07:55 PM
custm2500's Avatar
Ph.D. in HUBRIS
I have been happy with my interactions with HSW also! I will be running there noids. Highly reccomend HSW!
Old Oct 12, 2009 | 12:31 AM
no1izspeshl's Avatar
I would recommend the window switch then if you're a six speed. Also a fuel pressure safety switch at the least. You can get more technical with an a/f lean switch, but an FPSS does the trick. I personally am running a wet kit. Used to be a nozzle system but this summer I opted for the nitrous outlet plate conversion. I like it a lot more.
Old Oct 12, 2009 | 05:39 PM
Jeramey's Avatar
Yeah I am more then likely going to go with a wet kit using a plate. I will be using a window switch and fpss aswell. What kind of HP and TQ increases do you guys see with adding a 100 shot?
Old Oct 12, 2009 | 06:11 PM
2002t/a06's Avatar
I got 97rwhp and tq from a 100 wet. Had a lot more torque with the dry shot. It can vary though.
Old Oct 12, 2009 | 07:32 PM
98camaro28's Avatar
With my bottle pressure at 1100, I gained just a hair over 106 rwhp and about 200 lb. ft. on a 100 dry.
Old Oct 23, 2009 | 07:05 PM
Jeramey's Avatar
Alright, I have decided to go with a single wet 150 shot with TB plate and window switch. The car also has 5.7 TAE heads milled .030. Any recomendations on which kit to buy?.......
Old Oct 24, 2009 | 12:26 PM
dutinsss's Avatar
so you gained twice the torque with your dry kit 98camaro28?
Old Oct 26, 2009 | 04:15 PM
98camaro28's Avatar
Yeah it was about 200 more lb. ft. on a 100 shot.
Old Feb 10, 2010 | 06:23 PM
Jeramey's Avatar
Alright so tax returns are on there way and its time to make the decision. The mod list is as followed once again:
98 WS6, 38,500 miles, original motor.
Full exhaust, Pacesetter long tubes with cut out
Ported TB with Fast 90/90 intake
Comp .590 Cam
5.3L CI heads
Trexalia clutch
4:10 gears
420whp/400wtq
I have decided to go with a HSW wet plate kit, and spray 150 shot. Along with the HSW all out nitrous kit accessory that inculdes: HSW MicroEdge Nitrous Controller | Nitrous Bottle Heater Kit (4AN) | Nitrous Purge Kit (4AN) & Purge Wiring Kit | Nitrous Bottle Blow Down Tube Kit | Nitrous Filter Kit & 6AN Bottle Nut | Set of 8 NGK TR6 Spark Plugs. I am also going to get a Racetronix Fuel pump and wire kit.
I think that will make for a great set-up. Any opinions?
