Is there an all in 1 solution?
Old Oct 20, 2009 | 06:29 PM
rickou812's Avatar
Default Is there an all in 1 solution?
Is there anything out there that can do everything (besides the ligenfelter)?
Timing retard + 2 step + window switch + etc..
Thanks,
Rick
Old Oct 21, 2009 | 02:11 AM
camscam02's Avatar
besides an aftermarket pcm.... no.
you can use a timing tuner and a 2 step
or window switch and lingenfelter setup
hsw set up(dont remember if it pulls timing) + 2 step.
good luck
Old Oct 21, 2009 | 10:50 AM
kinglt-1's Avatar
look into the hsw microedge and hsw interface. You get full control over fuel/timing/nitrous with this pair of electronic controllers.
Old Oct 21, 2009 | 03:49 PM
FiFdYnUtz's Avatar
yeah microedge has the most options from what ive seen (gear lockout, AF shutoff, window switch, etc)
Old Oct 21, 2009 | 04:27 PM
rickou812's Avatar
It looks like to get everything I need I would have to have the:
Microedge @ $149.99
and MSD 6010 with EFI harness @ 309.99 + 83.99
Total = 543.97 + shipping
Old Oct 22, 2009 | 08:09 AM
transam69230's Avatar
Kinda of off topic, but I thought you needed a 4inch bore or bigger to run any type of LS3/L92 heads on a car. I notice that rickou812 you have an LS6 with these heads, how is it working out for you, what kind of power do you make?
Old Oct 22, 2009 | 08:41 AM
rickou812's Avatar
It is a big bore 383,(4.10 bore X 3.622 stroke). I have no dyno time, but plenty of track time, best so far in sig, but has more in it when I get all the bugs worked out.
Old Oct 22, 2009 | 11:20 AM
Oh okay, that makes more sense, is your block sleeved I was under the impression that you couldn't bore a stock cube block out that far.
Old Oct 22, 2009 | 03:19 PM
rickou812's Avatar
It is sleeved.
