Any A4 Guys Spraying On A Tsp 231/237 ?
Old Dec 8, 2003 | 10:51 AM
TWINK's Avatar
Default Any A4 Guys Spraying On A Tsp 231/237 ?
I Am Considering Going W The 231/237 W A Set Of Patriot Heads And 4000conv And 4:10's Any One W This Set Up Or Just The Cam ?
Old Dec 9, 2003 | 12:02 AM
CAT3's Avatar
Restricted User
I did, but then my trans blew on a little ole 200shot!
Old Dec 9, 2003 | 07:29 AM
WS6snake-eater's Avatar
Isn't 410s a little much for the spray in an A4? I was told that you would be out of gear before the end of the 1/4??????????Let me know because I would love to go with 410s....
Old Dec 9, 2003 | 07:00 PM
B18B1LS1's Avatar
It's going to depend on your tire and how high your willing to rev your motor. I'm running 4.30 gears and 30" tires on a 6400 rev limiter so I can stay in third through the traps.
Jeffrey
Old Dec 9, 2003 | 07:36 PM
Wow, I didn't think that was possible. I might be going to 4.10's then when I get the 12 bolt. Thanks.
Old Dec 10, 2003 | 08:17 PM
99 BG TA's Avatar
I would also like to know the results, of people spraying the 231/237 cam i am thinking about changing cams. I will also be adding a 100 shot.
Old Dec 11, 2003 | 01:57 AM
CAT3's Avatar
Restricted User
99 BG TA, not sure if I can handle stepping down to a 100shot, but if I find it in me I will let you know how it does on that little size
And of course a 150, and 200 if I keep the wet kit on. But once the NXL comes back its time for 180 or 220,
Old Dec 11, 2003 | 07:47 AM
99 BG TA's Avatar
cat3, maybe I should just step up to a 200 shot
Old Dec 11, 2003 | 09:36 PM
CAT3's Avatar
Restricted User
all smiles!
Old Dec 12, 2003 | 09:39 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
TWINK: It really kind of depends on your tire size, but I'd say that more than like 4.10's will be a bit much for MOST tires. Trevor ran a 3800 stall, 3.73's, 26-10-15 tires, and a 150 shot and he was having to go into OD before the end of the quarter mile. Do you know what tire you are going to run?
This cam LOVES nitrous, and makes some great power. We've had numerous A4 cars with this cam and Patriot Stage 2 heads and 100-150 shots making great power on the dyno, and awesome track times Feel free to e-mail or call me if you have any questions...I'd be more than happy to help make sure you get what you need to throw down the great track times.
Thanks,
MATT
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Dec 12, 2003 | 06:37 PM
CAT3's Avatar
Restricted User
I think I need to reduce timing, as Reckless has mentioned to me 100's of times, add an LS6 intake and maybe some S2 heads. I really think its to hard to hit 10's on stock LS1 intake, my chitty 2000heads....I have been sooo close, but its not a hand grenade.
This is in a DA of around 1500 or so most year long, is this not to good, or not to shabby?
Old Dec 15, 2003 | 06:25 PM
The Guy in MY 99TA's Avatar
I haven't done it but its in my plans.
I would have to speak up and say don't do the 4.10's UNLESS you have a 12 bolt or better!...... u might have been expecting some other reason but THEY WILL BREAK too easily! I broke my 3.73's and I'm on my 3.23's now and I haven't had any problems and they have been in for a few track days and they are working fine. the 3.73's lasted about 2 track days.(maybe 10-12 passes).
Also use a 28 tire.
Josh S.
