header size? 347ci 300+ hit, coating pistons and chambers
Old 12-08-2009, 07:15 PM
Race your car!
JL ws-6's Avatar
Put a cam in with about a 10 degree split and a 114 to 115 lsa, keep the lift under 630 so it's not hammering the valvetrain and you should be fine.
Old 12-09-2009, 11:12 AM
418redz28's Avatar
where do i look for coating pistons and chambers
Old 12-09-2009, 11:45 AM
ShiznityZ28's Avatar
Where ever you buy the pistons they can coat them. skip the chambers. 1 7/8 headers for sure unless 2" is in your price range.
Old 12-09-2009, 03:13 PM
8 second mod
Noyzee's Avatar
i wouldnt run 114 lsa cam. and i would not install it staight up. just my opinion tho
Old 12-09-2009, 03:18 PM
LSA is a random number until you know the duration, cam timming events and .05.....
example a 220 220 ona 114 is a different animal than say a 240 240 114. the ammount of overlap is more important than lsa...
Old 12-09-2009, 03:52 PM
Race your car!
JL ws-6's Avatar
Exactly. A 113 lsa on a 224 cam is a hell of alot different then say on the high 240 duration cam I've been running. You get into the overlap ad timing of things, and it's alot differnt.
Old 12-09-2009, 07:24 PM
418redz28's Avatar
from the way it sounds im missing out on some things... parts of being a newb i guess. but im up for learning if someone can give me a few more examples. i know this is area that is one of the most important parts of the motor and i know there is people i can have spec me a custom cam but i would like to actually know whats cause and effect.
Old 12-09-2009, 07:29 PM
418redz28's Avatar
i know u dont have to have a donky dick cam to go fast.. however i like the sound of it. its just something i perfer. i have so many questions i guess i should have titled this thread a lil bit of everything lol
Old 12-09-2009, 08:21 PM
BAKED's Avatar
I researched that quite a bit a while back and everyone was agreeing that if you coat the pistons, you need to coat the chambers too. At least in a big nitrous or FI application. They said that if you only do the pistons all the heat will be pushed into the chamber and make it more prone to detonate. These weren't your average joe's I was talking to about this, it was very experienced builders.
I'm not disagreeing with you because I've never tried it either way myself but it does make sense. Are the pistons in your all's motor coated but not the chambers? If so i take it you haven't had any issues?
Please explain, I'm interested in hearing other people's experiences with that.
Old 12-10-2009, 12:23 AM
slowredz's Avatar
Originally Posted by BAKED
The T-Rex is the last cam I would run in my motor. I just haven't been impressed with it. They usually make decent peak hp but if you look at the rest of the RPM range they aren't too impressive compared to some of the other cams. You don't need a big "mule dick" cam to go fast either, the cam in my car is just a **** hair bigger than a G5X2. Through a stalled auto, 9", and 325-50's my car made 435 to the tire and still had good mid range power. I don't have big fancy heads either, they are an old set of Absolute speed 2.5's, 853's to beat it all.
My setup made 711 rwhp one one big shot, I've never dyno'd it with both kits setup the way it is now, I'm just not crazy about spraying on the dyno.
The biggest part to the whole equation is going to be the tune up on the nitrous. If you don't know how to tune it then you are going to be leaving alot on the table and will more than likely hurt something eventually.
Be careful where you get your info, there are alot of people (and companies) that don't have enough real world experience with nitrous to be giving tuning advice.
You just ran a 6.03 making that much power?
I had a forged 346 and a TREX in a previous combo and it wouldnt pick up after anymore than a 200 shot. Made like 640 on 200 and 646 on a 250. nothing else changed in the setup except a custom cam and it made 689 on just 200
Old 12-10-2009, 07:53 AM
BAKED's Avatar
It wasn't making that much when I ran the 6.03 @ 114, I believe it was in the 670 range then.
It was WAY over timed and wouldn't make it all the way down the track without nipping a plug LOL. Since then I've learned how to go semi fast and keep it from hurting it's self.
Old 12-10-2009, 07:58 AM
  #32
Race your car!
JL ws-6's Avatar
How much were you sparying when it went 6.03 @ 114, last time I ran my car it went 6.09 @ 114.7 with a 1.41 60 foot (thanks E-town for the lovely prep!) I had the plate jetted to 65/43, I'm thinking it's still way too heavy on fuel (nos behind the tb plate on a fast intake)
I'm thinking, I have way too much fuel jet, we tried bumping a couple degrees to it, and it didn't do a damn thing, car basicially ran the same as it did 3 weeks earlier, went a mph faster and ran the same et with the 60 foot's about 1/2 a tenth slower... da was about 500 feet better so I'm thinking that the timing, pretty much did nothing, the mph was from the da, and the da made up for the weaker 60 foot.
Old 12-10-2009, 09:24 AM
  #33
What did the plugs look like?
Old 12-10-2009, 02:24 PM
  #34
gold98Z28's Avatar
if you could ever get that thing to 60' again, and run like it does now, it would be flyin. it leaves the line like stock car on a big tire, then traps 118/145
Old 12-10-2009, 02:40 PM
  #35
Race your car!
JL ws-6's Avatar
sending a pm
Old 12-10-2009, 02:54 PM
  #36
8 second mod
Noyzee's Avatar
i made 67x with a t rex cam with my 346 and a 300 shot. i put a smaller ESP1 cam in and made 703 and picked up about 2 tenths. thats what i went 9.4x a few years back with
Old 12-10-2009, 05:30 PM
  #37
418redz28's Avatar
dam most all u guys are hauling ***
Old 12-10-2009, 06:25 PM
  #38
Race your car!
JL ws-6's Avatar
Not really.... you look around at similar setups, I'm way off the pace. Have been all along really, we're always been very conservative with it. Probably why my junk's been together for 3 years and never had a head off it... but again, it's not anywhere what I would call impressive.
It's a pretty well built car, but it's always been on the heavy side, and tuned on the way safe side.
Now, I'm 300 lbs lighter, and am trying to stick with the same 9.50 speed, probably have to run negative timing to not goo too fast
So much for trying to push it
Old 12-10-2009, 06:38 PM
  #39
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
Originally Posted by FiFdYnUtz
i would run 1 7/8...irc they made more power then 1 3/4 pacesetters on a 346 bolt on car (like 12+hp) and you will want to get as much exhaust out as you can with that much spray...
YUP..I have the EDELBROCK stepped 1-3/4 to 1-7/8 coated headers....they give more sound also.
Old 12-10-2009, 07:07 PM
  #40
Race your car!
JL ws-6's Avatar
I do like the edlebrock header, I'd like themmore if they were stainlesss, that ti-tech doesn't hold up for ****, if they made that header in a 1 7/8 stepped to 2 inch I'd have bought them, I like the idea about being able to trim the primary's to length
Quick Reply: header size? 347ci 300+ hit, coating pistons and chambers
