Lingenfelter or HSW Microedge/Interface
Old 01-01-2010, 08:31 AM
choopak's Avatar
Old 01-04-2010, 11:35 PM
Mean87SS's Avatar
How would one tell the car to spray while on the two step and launching it?
Just ordered my Lingenfelter2step/nitrous kit today.
Old 01-05-2010, 03:03 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
the intructions outline the procedure to install a relay to deactivate the nitrous while on the 2-step...as soon as you disengage the 2step it will reactivate the nitrous.
Old 01-06-2010, 11:35 AM
LS1Tech Sponsor
Jason Haines @ LPE's Avatar
Default 2-step and timing retard
Yes, on the LNC-002 you can use it as a 2-step and also use it to retard timing while going down the track (or to retard timing at the line for boost built up). The two functions are separate.
The LNC-003 can only be used as a 2-step. It has two different RPM settings but no timing retard feature.
Originally Posted by C5_Pete
I've read a little bit about the Lnc-002 and I have a question for those of you using it.
You say you are using it to pull timing when you spray. Can you use it as a two step (Launch control) as well? or is it one or the other?
Thanks
