stock internal ls1+spray
Old Mar 24, 2010 | 12:15 AM
4bangermustang's Avatar
Originally Posted by Sofls1
Was Matt D at full weight?
not even close.
Old Mar 24, 2010 | 04:45 PM
Sofls1's Avatar
I have gone 10.57 @ 126
Stock LS6 with 175 shot at full weight (except skinnys) with a 2800 vig and mac headers.
I have gone to a SS3600 since then and have yet to get the car hook completely.
Old Mar 24, 2010 | 06:19 PM
fly pantera's Avatar
damn thats good.
matt D weighed around 3100-3200 and was only hitting it with a 75shot i believe.no more than a 100 shot.
I was thinking of throwing on some ported heads on mine.dont want to cam it cause i love it sounding stock than running fast times.
Old Mar 24, 2010 | 07:39 PM
jman54002's Avatar
Man that is fricking amazing... Would love to see a video and more specs.
Old Mar 24, 2010 | 10:28 PM
Sofls1's Avatar
Thanks guys,
Here is a video a friend of mine put together from a track rental this weekend.
http://www.youtube.com/watch?v=MI9KefKRuFA
On Sunday, I never went slower than 10.67, (except the pass I ran out of nitrous) but also never went faster than 10.63. I did pull off a 10.63@128.49mph with a lousy 1.52 60ft. Although it doesn't look like it in the video the car is spinning. I think I'm going to have to go to a 10" wide tire, and maybe an ARB.
I also think I have some false knock because knock sensors were pulling up to 4* in spots after I took out another 4*. I would pull 4* and it would just keep pulling timing, so I gotta figure that out. I was gonna try some 103, but car had too much pump gas in it.
There is definitely more in it.
Old Mar 24, 2010 | 10:53 PM
Pewter53's Avatar
dont know if this helps but heres my mods .
stock heads , stock motor, ls6 intake longtubes , lid and p.i 3600 converter. on a 100 shot. full weight but its a hardtop.
1/8 mile 7.15 and 95 w/ a 1.51 60ft
7.69 at 87 w/a 1.61 on motor
Old Apr 3, 2010 | 09:30 PM
ep142's Avatar
the guys running 10's is this on stock suspension? I am so close its killing me,
I have a 2000 z28 a4, full bolt ons, cam, 3700 stall, 150 shot wet, ET streets
only weight reduction- no rear seats or spare tire and jack. Bone stock suspension. 11.1 @122.8
http://s160.photobucket.com/albums/t...5.flv&newest=1
Old Apr 4, 2010 | 10:47 PM
I went 10.7 on factory stock susp minus lower control arms and a shity non-adj. torque arm(set at +2). but it 60'd like **** and MPH good.
Old Apr 5, 2010 | 06:33 PM
Sofls1's Avatar
BMR Lowers, Stock tq arm still mounted to trans, Hotchkis lowering springs, KYB agx shocks in back, QA1s in front, no frnt swaybar.
Old Apr 15, 2010 | 11:35 PM
ep142's Avatar
whats your best 60ft with that setup?
Old Apr 15, 2010 | 11:36 PM
ep142's Avatar
is yours an auto?
Old Apr 19, 2010 | 09:29 PM
  #32
4l80.
Old Apr 20, 2010 | 05:15 PM
  #33
Sofls1's Avatar
1.45 60ft.
However, that was with a small converter.
Old Apr 20, 2010 | 10:22 PM
  #34
BrianC98Z28's Avatar
sofls1 have you desensitized the knock sensors? I had to quite a bit as I was getting quite a bit of false knock on the launch and then it quickly zeroing out as it hit 2nd gear. I would log and launch and then kept desensitizing until it finally was all zeroed out on the launch. Best I did on stock tq arm was 1.49 and it bent the **** out of it and broke my mount on the trans.
Old Apr 20, 2010 | 11:03 PM
  #35
Sofls1's Avatar
I haven't de-sensitized them because I am not quite sure as to why the knock exists. The last outing I used VP103 still pulling timing and saw the same amount of knock. So even though I pulled an excessive amount of timing, and used good gas, kr was still almost 4*. The plugs look great even when I put some timing back in, so I'm inclined to say its false. At this time I have put this problem on the back burner cause the car is making good power even with less timing.
The problem I'm working on now is getting the car to hook again now that I have went to a 3600 stall from the 2800. I have gotten the car to hook relatively well on a track that was prepped really good, but it still did not work like it should. So I am working on taking care of some suspension issues on the car now. One of them will be taking the tq arm off the transmission. I have also finally upgraded to a draglite and 10" wide tire and corrected the IC of the control arms. I expect that the traction issues will be resolved next time out.
Old May 17, 2010 | 12:47 AM
  #36
HitmanLS1's Avatar
nice!!
Old May 17, 2010 | 10:42 AM
  #37
NOTFAST's Avatar
11.42 like 5 yrs ago...on 17's radials with no converter/stock trans
Old Jun 11, 2010 | 12:50 PM
  #38
ttt anyone quicker than matt d.stock longblock ls1 withnitrous.
btw martin luther has lost 60lbs since running 11.58 with boltons no nitrous.shooting for 10.49
Old Jun 11, 2010 | 10:01 PM
  #39
Sofls1's Avatar
Friend of mine has a stock longblock car that needs some more track time, but he is already as fast as matt d. In the next few weeks I anticipate he will be in the real low 10's
Old Jun 12, 2010 | 02:32 PM
  #40
jaschutz79's Avatar
I'll get her there. Only made two hits on spray. There is a 30 in there with traction. Now if i can just keep that cam i ordered out to see how far i can get it stock....
