lag on my system
Old Jan 19, 2010 | 11:41 AM
speeedo's Avatar
Default lag on my system
i have tnt F2 i notice sum lag arounde 5sec what should i do or why its laging ?
Old Jan 19, 2010 | 11:59 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Describe the lag please.
Old Jan 19, 2010 | 12:09 PM
speeedo's Avatar
i mean the system will respon aftre 5 sec or 7 sec not when i push it in the same time
Old Jan 19, 2010 | 12:38 PM
Internet Mechanic
How long are the lines from the selinoid to Injector?
Any delay box hooked up, or Window Switch.
What RPM are you spraying.
What PSI is the bottle.
Does the kit have a purge hooked up.
Old Jan 19, 2010 | 08:41 PM
speeedo's Avatar
1:lines about 5inch long selinoid to Injector
2:yes there are window switch
3:at 3200 RPM
4:i think 1000
5 yes i do have purge
thanks for your replay
Old Jan 19, 2010 | 11:01 PM
Nitro Dave's Nitrous Outlet's Avatar
There are many varables that come into play that can cause a delay.
It could be in the tune up. Caused by a lean or rich spike
It could be in the wiring. Poor connections or poor groounds.
It could be from a rpm drop when the car launches and hooks. The rpm drops and then it takes time for the car to reach the set rpm on the windowswitch to activate.
We need alittle more info.
Did you tune the car? If so tell us about the tune up.
Dave
Old Jan 20, 2010 | 08:28 AM
speeedo's Avatar
my tune up is ok i think you are right about the wiring i will chek it i feel i have poor connections or groounds cuse it use to be ok but i chang sum wire set up and it become lag
Old Jan 20, 2010 | 11:08 AM
Nick@HSW's Avatar
Does it lag all the time? Have you tried activating the kits in different scenarios?
Nick
