Went a little faster...
It was a great day today here in Sac, but it was abnormally hot, about 65-70 degrees compared to 50 or so when we ran that 9.86, so the first pass we had the 150s in again, it went 1.38 9.98 137, not to bad in the heat.
Put the 200 jets in it, 72 36 with the ngk 8s in it with a total of 16 degrees in it. Picked up 2 tenths and 3 mph and went...
1.36
6.20 @ 111mph
9.78 @ 140 mph
Nothing changed, still 3400 lbs still stock heads still stock bottom end and this FTI converter keeps shining.
Thanks to Harris Speed Works for all the help and hard work, they are the best in the business. Also thanks to FTI, my tuner Mark Romans and everybody else that has helped along the way. I want the cold weather to come back!
Cam
The next build we will build our own standalone low pressure system, just not needed in our eyes right now.
http://www.youtube.com/watch?v=wPSoWn2jn00
Your car is just bad a$$ I wish I could do with my H/C/I what you have done cam only. Keep up the good work.
Thanks man!
BTW figured out why it left to the left, we remembered the only non adjustable suspension piece on the car are the lcas, and when we had it scaled we were off by an 1/8 of inch, so when it wheelstood and only had the rear tires steering it thats why it went left. Nice easy fix.
to avoid this, you want to contact a converter builder and have them build you the best converter for what you want to do.
a4, decisions decisions...
car looked good and the exhaust looked pretty clean( tells alot about the tune) I only saw 2 small puffs. car is making good power with that mph.
