Stand Alone Fuel System
I am thinking of going with a Stand Alone Fuel System. Will my jetting change at all? I will be going wiith the Harris Speed Works system. The kit I have is a NX single piece MAF kit on a silverado SS with a 150 shot. Thanks any advantages or disadvantages?
As long as you dial in the same flowing fuel pressure the jetting will not change. There really are no disadvantages. Advantages are you pull the strain off the cars fuel system. You can also run leaded race gas in it.
Check out our systems as well. We are the ones that designed and brought to market the all in one dedicated fuel systems.
We offer our aluminum series that consist of a unit that mounts in the factory battery location as well as one that bolts to the front core support by the radiator and does not require moving or modifyining anything.
We recently just released our plastic series and they have a killer price tag on them right now.
https://ls1tech.com/forums/nitrous-o...l-systems.html
Guest
Posts: n/a
We sure do
http://www.nitrousoutlet.com/catalog...hButton=Search ( Click on the part # to bring up the descripton / picture )
The race gas will help cut down on detonation so you can get away with running a little bit more of a shot. Always make sure your tune, afrs and plugs readings are spot on.
