nitrous outlet bottle nut question
Old Mar 5, 2010 | 05:19 PM
PONTIAC SLP's Avatar
Default nitrous outlet bottle nut question
Hi , I bought used bottle , the bottle nut is 4AN , my kit is 6AN and i want to order 6AN nut but i don't know what i order , this will works ? http://www.nitrousoutlet.com/catalog...5&product=2744
Attached Thumbnails nitrous outlet bottle nut question-20100306096.jpg   nitrous outlet bottle nut question-20100306098.jpg
Old Mar 5, 2010 | 05:45 PM
Nitro Dave's Nitrous Outlet's Avatar
That bottle has me alittle scared..... From the picture it looks like someone removed the safety blow off fitting in the valve and put a plug in it...IF that is the case you need to redo that as fast as possible before someone gets hurt.....
Those are 326 style valves..
You need this.
Bottle nut.
http://www.nitrousoutlet.com/catalog...1&product=2548
6 an bottle nipple.
http://www.nitrousoutlet.com/catalog...1&product=2549
Take a picture of the back of the valve please sir.
Old Mar 5, 2010 | 07:35 PM
new pictures , what i need to be in save ? and what bottle nut i need ? because i have the 6AN line
Attached Thumbnails nitrous outlet bottle nut question-cimg1822-620-x-876-.jpg   nitrous outlet bottle nut question-cimg1824-600-x-450-.jpg   nitrous outlet bottle nut question-cimg1825-912-x-684-.jpg   nitrous outlet bottle nut question-cimg1829-912-x-684-.jpg   nitrous outlet bottle nut question-cimg1830-600-x-450-.jpg
Old Mar 5, 2010 | 09:58 PM
itsslow98's Avatar
+1 how old is the bottle after I believe 3 yrs you are supposed to have it recertified especially if you havent owned it since it was new. And put a blow down on ASAP.
Old Mar 5, 2010 | 10:26 PM
sprayedenali's Avatar
ya, you probably want to take that bolt out of the pressure relief port, or whatever its called, pretty damn soon!!!!! who ever's idea that was, well... lets just say it wasnt the smartest thing to do
Old Mar 5, 2010 | 10:37 PM
'Trust''s Avatar
No joke, death by bottle shrapnel is a bad way to go.
Old Mar 5, 2010 | 10:45 PM
wheres the thread/pictures of that car that got DESTROYED when the bottle exploded?
Old Mar 5, 2010 | 10:55 PM
fucter's Avatar
Man, I'm really holding back some comments for the sake of being nice.
Old Mar 6, 2010 | 12:38 AM
oh damn !! thanks guys for the advice , I placed my order today
which Blow Down i should add to the order ? i'll put dual 10lbs bottles in the car because i'm spraying 250HP .
Old Mar 6, 2010 | 12:48 AM
the date of manufacture is 2006
Old Mar 6, 2010 | 12:58 AM
itsslow98's Avatar
http://www.nitrousoutlet.com/catalog...=23&section=75
00-35001 part number for rupture disc, check to see if thats the correct one with nitrous outlet
the blow down tube itslef can be braided line like in the link or a metal tube.
You may seriously want to get the bottle checked. The guy who had it before may have exceeded the 3000psi and ruptured the disc causing it to release the pressure and he was too cheap to put a new one on hence why it is capped up(once the disc ruptures it has to be replaced). There really is no reason not to have one on there.
Old Mar 7, 2010 | 11:50 PM
Yes that is a plug in the Blow off port. This is extremly important that you remove that. If who ever put that into the valve bottomed it out in the port you will more than likely need to replace the valve. The back of the port has to have a smooth flat surface for the blow off fitting to compress the blow off disc between the valve and fitting.
If you can take that plug out and take a really good picture I may be able to tell you if it needs replaced.
Dave
Old Mar 8, 2010 | 03:31 AM
Dave
okay so , don't processed the order till i take a picture to add parts to the order , wich one you are talking about # 1 or 2 ?
thanks
Attached Thumbnails nitrous outlet bottle nut question-cimg1829-20-912-20x-20684-.jpg
Old Mar 8, 2010 | 03:45 AM
itsslow98's Avatar
#1 but dont take that cap off if there is anything in the bottle.
Old Mar 8, 2010 | 03:51 AM
lol , I don't want to lose my life , thanks buddy .
Old Mar 9, 2010 | 07:02 AM
hey dave here is the picture
Attached Thumbnails nitrous outlet bottle nut question-cimg1845-912-x-684-.jpg
Old Mar 9, 2010 | 10:30 AM
hey guys at nitrous outlet i placed my order in 4 days , I sent a private message to Dave and he did't replied me and also sent to sales@nitrousoutlet.com and the same !! hey guys whats wrong , I want to know which blow down i should run with , so please give me quote on that
Old Mar 13, 2010 | 02:20 AM
thanks a alot nitrous outlet , it was my mistake when i was so hasty but they help me to order the right part , specially thanks for Dave and Grant , I'm sorry for the above post
Old Mar 16, 2010 | 01:24 AM
No problem.. We are happy to help.. Thanks for all the support..
