Information on Plug Reading?
Old Apr 2, 2010 | 01:58 PM
  #41
ATVracr's Avatar
Originally Posted by Gary Z
None of your big shot comments help the OP. My original post was merely intended to counter the absurd claim that a wideband is “useless” for tuning a nitrous engine. Despite the obvious limitation you harp upon, a wideband can, for example, show that a nitrous engine is lean at 5000 rpm and rich at 7000. This is good information and is much more realistic than your extreme examples. Sorry I rattled your cage.
Sorry your clueless.
He was right a single wideband alone doesnt tell you ****.
Your taking an AVERAGE A/F of 1/2 the motor and ASSuming all the plugs look the same.
Whats so hard to understand about that not being the right way to tune a nitrous car?
Put a 02 sensors in each header tube and you would have something.
But since it cost about $3,000 to do that last time I checked not many will do it.
So instead you can read all 8 plugs simple and alot cheaper.
Old Apr 2, 2010 | 02:11 PM
  #42
ryarbrough's Avatar
****. Not only would you need O2 sensors, but also EGT's to get you all of the info you can get from reading the plugs. Add another grand for a cheap set of 8. I can get 80 B8EFS plugs for like 160 to my door. What do you think I tune off of.
Yes, people have gotten away with wideband tuning on these smaller shots, but it never hurts to use those kind of shots to learn how to properly read a plug. That way, when you decide to build a real motor and hit it hard you know what the hell you are doing.
Old Apr 2, 2010 | 02:55 PM
  #43
ATVracr's Avatar
Holy ****!! I thought I was the only one who understands.
Exactly right on!
I just told Steve yesturday we should post a pic of the 40 boxes of spark plugs we just go in. LOL
That might last us a month or two.
Old Apr 2, 2010 | 03:22 PM
  #44
N2OGMC's Avatar
Even if you have a WB 02 in each header they still really dont tell you anything, because the thing can be 9-1 and it will burn up or it can be reading 14-1 and burn up and then what are you gonna do.
We had 8 o2's and 8 egt's in one of are Promods and after the first few passes they never looked at them again and we have never put another WB on any of them.
The only way to tune is reading plugs....
Old Apr 2, 2010 | 03:24 PM
  #45
N20GMC's Avatar
Whoops wrong screen name.
Old Apr 2, 2010 | 03:45 PM
  #46
ATVracr's Avatar
Agreed
They can tell you if something changes once you figure out what the A/F is when the plug looks right. They can also help you if something is off in the middle of the track.
Hope that makes sense.
  #47
ryarbrough's Avatar
Exactly right on!
I can't tell you the last time I looked at my wideband. Why should I look at another data point that is pretty much useless when I have 8 more cylinder specific and more reliable data points to use. Hell, even the Federal Judiciary agrees with my logic here. Anyone ever heard of the "Rule of Best Evidence"
Old Apr 2, 2010 | 04:24 PM
  #48
N20GMC's Avatar
Agreed
Oh yes I understand completely. Once you get the tune right from reading the plug. You can see what it was on the EGT and o2.
Old Apr 3, 2010 | 07:12 AM
  #49
gregrob's Avatar
ATV Racer is a ******* dick head.
that is all
Old Apr 3, 2010 | 07:27 AM
  #50
gregrob's Avatar
Other than installing thermo-coupler sensors measuring EGT (Exhaust Gas Temerature), the only real way to know what is happening inside your engine is to read the spark plugs. Both the fuel mixture and the ignition timing result in coloring of the spark plug’s porcelain and ground strap. The trick is to how to get the correct coloring without going into detonation and destroying the engine or by going too rich and raising the ring lands.
Spark plugs can only be correctly read if the car has been shut down immediately at the end of a run without driving it back to the pits. Get off the track and coast to a place you are safely out of the way and either read the plug there or change one or two with some you have in your pocket so you can read these uncontaminated plugs when back to the pits or simply tow the car back. It may take a couple of runs to get see the spark plug color.
The porcelain around the plug’s center electrode can be divided into three areas for reading. The area that is closest to the tip is affected by the idle and transition carburetor circuits and is of no real concern to a racer. If this area is gray then you drove the car back to the pits and you cannot correctly read the plugs. The middle area is only colored when you drive down the road at around a steady 30-40 mph and is normally affected by the primary circuit jetting with the power valve closed and this is really of no concern to the racer. The area you are interested in is that third that is all the way up inside the plug where the sun dosen't shine. This area is colored when all is wide open under full power because the combustion chamber heat totally cleans off the other two areas. It will take a special plug reading flashlight with the magnifying glass to view it correctly. Plugs cannot be correctly read by just quickly looking at them with the naked eye. You see people doing it all the time because they don't know what they are doing.
Normally aspirated cars should have a light gray or tan hydrocarbon ring or as some call it a "fuel ring" all the way up inside around the third area closest to the point where the porcelain is attached to the metal jacket of the plug. The actual color may depend on type of fuel you use. This fuel ring should appear like a light shadow. Most VP C-15, C-16 or C23+ fuels will show as a light gray when correct. This fuel ring starts to color on the porcelain side that is below the ground strap and works its way around either side of the center electrode until it completely joins. Sometimes it may take two or three runs to see a good coloring. Note: New engines or engines that pump a little oil may show a thin oily line way down inside on the porcelain where the porcelain meets the metal wall of the plug. This oil line has nothing to do with the air/fuel mixture but may be confused with the fuel ring you are looking for.
If you are having a hard time figuring out if what you are reading is correct or because you are not sure if the plug heat range is correct then tow the car back to the pits and drop the headers and look inside the pipes. If they are black then you are too rich, if they are light gray or white then you are too lean. The pipes should be a medium to dark gray or tan color. Normally the white area of the porcelain has a chalky appearance. If you see the porcelain take on a shine then it is time to change the plugs because the glass that is in the porcelain has been melted and has glazed the surface. If the car has been running rich (due to lots of idling or incorrect fuel mixture) then it is possible to glaze the plugs and short them out during a run because of the sudden heating of the plug with the soot on the porcelain. This glazing appears to be a glossy coating on the porcelain with a splotches of color of greenish yellow or brown. These two different glazings will cause the plug to short out and misfire and raise ring lands or make a popping through the exhaust when going down the track.
Ignition timing is directly responsible for the heat in the combustion chamber and therefore the color of the plug’s ground strap and the color of the first few threads on the outside of the plug. The ignition timing can be checked by looking at the color of the plug’s ground strap and the position of the "blue line" on the strap. The blue line really indicates the point at which the strap has reached annealing temperature of the metal. To help to understand this, think of a bar of steel (ground strap) on a table that is being super heated with a acetylene torch at one of the tip ends. As the end heats up and the heat starts moving down the bar you will see a blue line across the bar at some point down the bar away from tip with the torch. This blue line reflects the temperature that is the annealing point of the metal. As the temperature increases the blue line moves further down the bar away from the torch. Similarly, the blue line moves down the spark plug ground strap as you put more heat in the engine. If you are using a gold colored ground strap like with an NGK spark plug then not enough timing will show the ground strap as still gold or going light gray maybe with a few bubbles on it after a run. As you advance the ignition and put heat in the engine the plug ground strap will turn darker gray as well as the metal at the end of the threaded area.
As the metal turns medium to dark gray you should start looking for the blue line (band) around the ground strap. Ideally, you want this blue line to be just below where the ground strap makes the sharp bend and above the weld. If you advance the ignition too far the blue will disappear off the strap and the strap will pick up rainbow colors (blues and greens). The next step beyond that is to start melting the strap from the tip end and detonation. When you are close to the correct timing then only change the timing by one degree at a time. If your ignition system has the capability of adjusting the timing of each cylinder independently (ICT), then you can use that feature to have the blue line in the same position on all the plugs.
First, adjust the basic timing to get as many of the plugs to have the blue line just at the sharp bend in the strap. Now adjust the ICT to move the blue line to the same point on the remaining plugs. Once all the plugs read the same you can advance the ignition a little at a time to put the blue line just above the weld on the strap or whatever point gives you the best performance.
The round flat circular area of the plug at the end of the threads should be dark gray or flat black and should not be sooty. If it is sooty then it can mean that your plug has not been tightened enough and you are sucking and blowing fuel and air past the threads of the plug. Detonation shows up on the plugs as spotting on the porcelain. There are two different types of spotting seen. One type appears as just black spots and the other appears as little bright spots like diamonds. The black spots (look like pepper sprinkled on the plug) indicate a little too much heat on the plug which causes detonation by having the heated plug fire off the mixture prior to the spark firing. This creates two flame fronts that collide and can cause great amounts of damage. If you see black spots on the porcelain and you know the tune-up is correct then you may need a colder plug. If you are not sure, then increase the carburetor jet size slightly, take out some timing, or go to a colder plug. If you hold the plug in the sun and you see what appears to be small diamonds on the porcelain then your detonation is severe enough to be blowing off the aluminum from your piston and you need to add fuel and/or take out timing immediately.
If you keep on adding timing until your finish MPH falls off but you still have no color on the plug’s ground strap but the porcelain has good color then your plug is too cold. If you have lots of color on the ground strap but the porcelain is clean and white then the plug heat range is too hot. The heat from the plug is cleaning off the fuel ring from the porcelain.
Credits to here: http://www.race-mart.com/Tech_Talk.asp
Old Apr 3, 2010 | 07:58 AM
  #51
ATVracr's Avatar
that is all
Sorry if facts and knowledge offend you.
If I call you stupid for posting something dumb and you take offense to it I dont really care.
Have a nice day.
Old Apr 3, 2010 | 09:34 AM
  #52
ShiznityZ28's Avatar
I talk to ATV at least 3 times a week and he is a d1Ckhead..... I wish people would realize im the nice guy hahahaha.
Old Apr 3, 2010 | 11:01 AM
  #53
87silverbullet's Avatar
Usually when you talk to a person 3 times a week it means they're your psychologist.
Old Apr 3, 2010 | 12:24 PM
  #54
3fingas's Avatar
or your wife...LOL
Old Apr 3, 2010 | 04:27 PM
  #55
ryarbrough's Avatar
that is all
Hey... I resemble that comment... I'm sure he will cry himself to sleep over it. LOL
Old Apr 6, 2010 | 09:49 AM
  #56
I see wayne and the car more than my wife durring race season. LOL
