Information on Plug Reading?
Old Mar 11, 2010 | 04:04 PM
SkullV's Avatar
Default Information on Plug Reading?
I was wondering if you guys have any good web sites, books, or other literature about reading plugs? I have the basics down, but I am always interested in learning more. My buddy who also tunes cars is always with me to help read the plugs when I am spraying but it would be great to be able to do it myself without him watching over my shoulder!
Old Mar 11, 2010 | 04:23 PM
billy.johnson's Avatar
A Wide band would be great help for you to....
Old Mar 11, 2010 | 04:58 PM
SkullV's Avatar
Already have a wideband in the car, running NGK BR7EF @.033, I log every pass with HPtuners, my afr is always good as far as the wideband is concerned, but I still want to read the plugs.
Old Mar 11, 2010 | 05:13 PM
ryarbrough's Avatar
Here is a great thread about it on the bullet... Let me see if I can find it
Old Mar 11, 2010 | 07:29 PM
SkullV's Avatar
That would be great!
Old Mar 12, 2010 | 12:50 AM
SkullV's Avatar
I found a couple articles though google, but they are all pretty vague, anyone have anything good to read?
Old Mar 12, 2010 | 01:28 PM
Bandit28's Avatar
You can go to a class for reading plugs i think it cost around $300 they travel from state to state. Steve and Monty put the class on I do believe.
Old Mar 12, 2010 | 03:57 PM
SkullV's Avatar
A class would be sweet, but I'm pretty good at reading up on stuff, and my buddy can fill in the blanks for me if I have any serious questions. Still looking for a book, web page, magazine article, anything with some good info on plug reading.
Old Mar 14, 2010 | 09:27 PM
WE TODD DID's Avatar
A wide band doesn't read the plugs. It takes an average a/f ratio of the engine, which is pretty much useless.
Old Mar 14, 2010 | 11:12 PM
danieloneil01's Avatar
Useless? Um, if it keeps someone from going all out when they see the A/F mixture way lean and saves their engine I'd call that very useful. Yes tuning it by a pro would keep it safe. But a solenoid getting stuck can happen and reading the plug after this would be useless since the engine would be getting rebuilt. There's plenty of other things that save an engine by having a Wideband.
Just for *****, why does a tuner use one when tuning?
Old Mar 15, 2010 | 07:48 AM
Leaning out an engine doesn't hurt parts. Too much timing, detonation, and too much fuel does. Besides, how do you know what is too lean, or too rich for that matter, if you don't look at the plugs? There is no perfect a/f ratio. You tune by the plugs, and whatever a/f ratio you end up with, is what it is.
Old Mar 15, 2010 | 07:50 AM
Probably because they don't know how to read plugs, or are just too lazy to, or simply don't know any better.
Old Mar 15, 2010 | 08:38 AM
ATVracr's Avatar
If #7 plug is running at 15.0 A/F and #1 plug is running at 10.0 A/F
then the other 2 are "OK" and your wideband says your at 11.8 A/F so you think your good to go.
Your probably gonna hurt number 1 and 7 both but for different reasons.
Plugs will tell you whats going on and like ^ said A/F just gives you an average.
Old Mar 15, 2010 | 10:19 AM
SkullV's Avatar
Great info guys (even though I already knew that). Still looking for plug reading info.
Old Mar 16, 2010 | 07:22 AM
There are a couple different ways that people do this. I get my fuel reading from the base of the porcelin. In order to do this, you'll have to cut the threads away to reveal the base of the porcelin. I don't like to see any fuel with the naked eye. With a single, smaller system, a little fuel would be ok. As far as timing, I like my timing mark to be around half way between the start of the bend of the ground strap, and the tip of the ground strap. Each application will be a little different, as your time slips will tell you what it likes. Hope this makes a little sense.
Old Mar 26, 2010 | 08:12 PM
ws6whore89's Avatar
Question, when reading plugs, they don't have to be BRAND NEW plugs do they? Can I just go do a run now that I have had plugs in for 5,000+ miles and shut it down right away and read the plugs?
Old Mar 26, 2010 | 09:15 PM
ryarbrough's Avatar
Put new plugs in it right before the pass. Your method will make it harder to read them.
Old Mar 31, 2010 | 09:01 PM
Gary Z's Avatar
If your distribution is so poor that a wideband is useless then you probably should try dry or direct port. I'm not saying you don't need to read plugs. I just think you shouldn't accept poor distrubution.
Old Mar 31, 2010 | 10:17 PM
JRracing's Avatar
I got a good one. Let me figure out how to post it.
Old Mar 31, 2010 | 10:19 PM
ATVracr's Avatar
Your a retard and have NO CLUE about nitrous tuning.
Thank you drive thru.
