Nitrous AN line size, quick question.
Take your pick...
Earl's Blue
Earl's Silver
Russel's Blue
Nick
I never thought to see if they would work on the solenoid outputs. I assumed they were the same and wouldn't work. We stock the 90 degree fittings. We have them in blue and black.
OUr plate systems comes standard with 3 an hose on the fuel feeding from the solenoid to the plate. On the Nitrous solenoid to plate we use what we call a race hose. Its a 4 an hose with a 3 an nut on the end that connects to the plate.
All our efi systems come standard with 4 an main feed lines as they can support up to about 300 hp. All our directports come standard with 6an hoses. You can upgrade any of our systems to a 6an hose at the time of purchase and I believe it cost roughly 15 dollars. The reason we do not send our efi systems standard with 6 an main feed lines is because the 6 an is bulkier and not as flexable to easily run through the car. We have found most efi guys are not spraying over the capabilities of the 4an hose unless they are running a directport. So why charge them for what they dont need. :-)
As far as our solenoids and plate they will easily flow 400 hp..
