Nitrous AN line size, quick question.
Old Mar 15, 2010 | 11:43 PM
01SOMZ28's Avatar
Default Nitrous AN line size, quick question.
Whats the AN size of most average nitrous lines? I need a longer nitrous line and i'm not sure if its 4AN or 6AN, i was thinking its 4AN but i'm not 100% sure.
Old Mar 15, 2010 | 11:45 PM
'Trust''s Avatar
Most are -4AN, I opted for a -6AN line on mine, but it was an upgrade.
Old Mar 15, 2010 | 11:51 PM
01SOMZ28's Avatar
What are some advantage's to upgrading to a -6AN? more flow i take it? Would it be beneficial for me to upgrade to that or just stick with the -4AN? I'm only running a 150 shot but will be spraying 200 in the near future.
Old Mar 15, 2010 | 11:56 PM
itsslow98's Avatar
i had -4an for my 150 shot, i would ask someone like HSW or Nitrous outlet and see what they say, most of the fitting will need to be swapped for -6an line which can get pricey as well.
Old Mar 16, 2010 | 12:11 AM
Nitro Dave's Nitrous Outlet's Avatar
Most standard systems are 4 an. Systems like directports usualy come with 6 an.
Here is a fast way to tell.
If you use a 9/16 wrench on the B-nut to disconnect from the bottle its 4 an. If you use an 11/16 its 6 an.
Dave
Old Mar 16, 2010 | 12:28 AM
01SOMZ28's Avatar
Thanks for the help guys, it was a noob question but i wanted to be a 100% sure because i need to order a line and some 90 degree fittings.
Old Mar 16, 2010 | 12:30 AM
Everyone using nitrous has asked that same question at some point.. Thats how you learn.
Old Mar 16, 2010 | 07:26 AM
'Trust''s Avatar
I'm no where near experienced enough with N2O to answer that question properly. I'd ask Nitro Dave if it's needed to run a -6AN on the 200's, my guess is it isn't needed but perhaps would be suggested?
Old Mar 16, 2010 | 11:42 AM
Nick@HSW's Avatar
All of our brute force systems that are rated that high come with a -6 feed line. Is it 100% necessary? No. Is it suggested? Yes, highly.
Nick
Old Mar 16, 2010 | 05:00 PM
conde'strans's Avatar
Nick
Ok that being said, could my HSW wet plate kit handle a 175 or 200 shot if I decide to upgrade from the 150?
Don't wanna hijack but since it's related!
Old Mar 16, 2010 | 09:55 PM
itsslow98's Avatar
my guess is yes you should be good to 250 i believe, after thats its direct port.
Old Mar 17, 2010 | 10:53 AM
Nick@HSW's Avatar
Depends on which system it is. Shoot me a PM with your name and I'll look you up in the system.
Nick
Old Mar 17, 2010 | 07:41 PM
Hard Core Z28's Avatar
When should you go from a 4an to 6an. More n20?
Old Mar 18, 2010 | 02:31 AM
itsslow98's Avatar
yes..
Old Mar 18, 2010 | 07:47 AM
JRracing's Avatar
What if a guy is running a nano bottle on a Edlebrock Performer RPM plate kit. Would it change anything going from a -4 to a -6 main line? Is it going to change the output from the nano at all?
Old Mar 18, 2010 | 02:48 PM
01SOMZ28's Avatar
So i just got my 90 degree fittings in the mail. I went to put them on and they're to big! I don't know what size my line is if these are supposed to be -4AN and my line is supposed to be -4AN. I'm confused...i'll get some pics in a minute and hopefully some of you guys can help me...since i just spent $60 on fittings from summit...
Old Mar 18, 2010 | 03:00 PM
01SOMZ28's Avatar
here are some pics, i hope they help.
what size is the fitting coming off the nitrous plate? Because my lines screw onto that just fine...I needed the 90 fittings because my lines are a little to short and i didn't want a hard bend in the line to screw into the plate and a 90 would fix that.
Old Mar 18, 2010 | 03:17 PM
Nick@HSW's Avatar
Jet holder fittings are 3AN in size.
Nick
Old Mar 18, 2010 | 03:33 PM
01SOMZ28's Avatar
So then i need 3AN fittings? I need 2 90 degree fittings to come off the n20/fuel solenoids and 2 to come off the nitrous plate. Where i can i get 90 degree 3AN fittings with male and female ends?
Old Mar 19, 2010 | 10:07 AM
Nick@HSW's Avatar
Well first verify that those fittings are too big for the solenoid outputs before you return them...you might only need 2 3AN 90's.
Take your pick...
Earl's Blue
Earl's Silver
Russel's Blue
Nick
