how much nitrious can you put on a stock ls1?
how much power loss do you guys think you'll get by pulling 2 degrees of timing when your normally running the car. I know its alot safer when using nitrous and ive pulled 7 degrees in the past on my LT1. Im just curious of the power loss i know on my LT1 with that much pulled the car wouldnt pull at all above 4000rpms.
Does this make a difference if its going on an A4 or M6? I have an A4 and want to run a 100 shot. Would that be too much for it? I am stock now but will be adding H/C/I at the same time if I can find a good tuner in SLC,UT area.
8 second mod
yea, im putting my big intake on the 346. lol between that and my 2" headers im going to use this motor should have no bottom end at all.
the intake makes power where this motor is going to red line. lol
was spinning my 427 to 8300-8500. this thing will be done high 6,000 range. lol
