What I was told is that you can leave the nano bottle open and just close the nitrous bottle because of the check valve. That way once you open the nitrous bottle the nano will just bring the pressure up from that point.
I think the only time you would need one would be when the bottle was full and not up to pressure. The nano PSI is much higher than the N2Os so it should transfer, but I don't know at what point the bottle itself is thinking it is full.
Brad said you can leave the Nano bottle open at all time. Then when you want to spary, just open you Nitrous bottle. So you can still use the ele open with the Nano setup.
Awesome, thanks!!! I was a little concerned, but was hoping for that answer
