Removing nitrous kit... have a question about fuel rail
I've sold my nitrous kit and I'm in the process of removing it. Only snag I've run into is the fuel solenoid line plumbs into the end of the driver side fuel rail. My question is, was there a factory cap on the end of the fuel rail, because I don't have one. Can I buy something in a certain size from an autoparts store that will work?
Thank you in advance.
yea cap is nothing more important is the schrader valve (like a valve stem core) i believe you remove it when you install the fuel sol.... i need to get parts to extend my rail out an inch or so so i can install my fuel sol. myself haha
You can get a schrader valve at any local auto parts store. Its the same valve that used in the valve stem for your wheels. You will find it in the tire repair section. It usually comes with about 5 schrader valves and a tool to remove/install them.
The cap is threaded on, but it is not what seals the end of the rail.
You could also just do a 4AN cap, but please be very very careful when tightening it...its so easy to break off the threaded end of the fuel rail trying to get a good seal. IMO the stock shraeder valve is a better solution.
Nick
