250 shot, stroker or not
Old Jan 2, 2004 | 10:31 PM
Jammer's Avatar
Default 250 shot, stroker or not
Guys, if you were to build a motor for a 250 shot, what stroke/bore is ideal (please no c5r ideas) Is a stroker okay, what are the pitfalls. Would iron block and cubes be best? Whats ideal?
Old Jan 3, 2004 | 01:25 AM
Jammer's Avatar
36 views, no comments...come on guyz
This is for another winter project to battle the twins
Old Jan 3, 2004 | 03:17 AM
C4VetteLS1's Avatar
If you want a bulletpoof street/strip killer with ultimate reliability...then the 409" Iron block 4"strokex4"bore setup....
It will handle a ton of nitrous if setup for it and will scream on motor...
Old Jan 3, 2004 | 02:30 PM
SStroked 410's Avatar
I am starting with a 200 shot on my 409 (4.000 stroke 4.040 bore) when I get everything together. These strokers can make really good power on motor and spray. I am still trying to decide if I should go with Diamond or Lunati pistons since I want to someday spray a 300 shot.
Only pitfall I see about these iron blocks is the weight but the nitrous makes up for it
C4LS1
Nice cam
hows the rwhp rwtq on motor and spray?
Old Jan 3, 2004 | 11:51 PM
Jammer's Avatar
Thannks Guys...C4Vette,,,,you have the eagle crank motor built an in?
Looks like thats thye direction were gonna go ....409!
Old Jan 4, 2004 | 12:03 AM
verbs's Avatar
How does C4 vette already have the LSX intake?
Old Jan 4, 2004 | 01:30 AM
C4VetteLS1's Avatar
Verbs: Thats the one thing i dont have on the car yet. Im a compcams dealer and i wont recieve my intake for another week or two.... So i guess my sig can be slightly decieving...
And i havent ran my new 409" yet because im waiting on it. my sig and pic were from the forged 346 that was in the car before with a TON of spray on it...
Old Jan 4, 2004 | 11:02 PM
Jammer's Avatar
So...to get this strait....most feel the stroker (iron or not) is as good /reliable/ strong for a 200 shot as a traditional stroke?
Old Jan 8, 2004 | 03:37 PM
sr71bb's Avatar
The theory is the BIGGER the bore the bigger the shot can be handled because the heat and pressures attributed to the introduction of the juice are contained in a larger area. So in this sense the STROKE would not make any difference. Things that ALSO so be considered are larger exhaust valves. oringed and receiver grooved blocks and heads, thermal coatings. Lower compression motors also can take more juice because their cylinder pressures are less to begin with. Also in theory the SHORTER the rod, the STRONGER the structual strength (here I suppose we get back to stroke).
Old Jan 8, 2004 | 11:58 PM
Jammer's Avatar
Thank you...were goona try a 409 .
