what plugs??
Old Apr 12, 2010 | 02:41 PM
jcuadra's Avatar
Default what plugs??
im running a ms4 with bolt-ons and a wet 100hp shot through a hsw sudden impact plate kit and i wanted to know what would be the best plugs to run.. i wont be spraying alot of the time and this is my dd
Old Apr 12, 2010 | 03:26 PM
87silverbullet's Avatar
NGK br6ef for the 100 shot. br7ef if you are going to shoot anymore than that.
Old Apr 12, 2010 | 07:35 PM
kinglt-1's Avatar
Id say a br7ef with your setup.
Old Apr 13, 2010 | 10:30 AM
chknhwk01's Avatar
Wink ...........................yo 100 shot........................
stay what works ngk tr6,s that plug is good for u... 200 shot, then ngk tr7,s
Old Apr 13, 2010 | 11:50 AM
ryarbrough's Avatar
Read the projected tip plug thread and stop telling people to run a TR6. There is no such thing as a TR7 - Only a TR7IX which is an iridium plug and not good for nitrous for two reasons (projected tip and iridium).
OP - I'd put a br6ef in the car with the 100 shot. I might even go with a br7ef for a little added security and the ability to bump the shot up without changing the plugs.
Old Apr 13, 2010 | 01:36 PM
Nitro Dave's Nitrous Outlet's Avatar
I would use the BR7EF and be done with it.
Old Apr 13, 2010 | 09:43 PM
kalebm22's Avatar
Restricted User
dont mean to hijack, but would the br7ef be good for my setup up to 200hp on a wet shot?
Old Apr 14, 2010 | 10:09 AM
Yes you could use a br7ef on a 200 but a 8 will give you a little added insurance. Put the 8 in and look at them and you will see if you need a warmer plug. Better to be safe then sorry.
Old Apr 14, 2010 | 10:10 AM
You need to stop googling yourself.
Old Apr 14, 2010 | 10:22 AM
kinglt-1's Avatar
Old Apr 14, 2010 | 10:58 AM
ryarbrough's Avatar
Thwo the b8ef plugs in.
Old Apr 14, 2010 | 12:02 PM
kinglt-1's Avatar
x2 go with the br8ef for a 200shot.
Old Apr 14, 2010 | 01:43 PM
wforty94's Avatar
So for all the people that have been running the TR6’s for all these years were mistaken?! Not that I don’t think a non projected plug will be better for nitrous applications but I think for most people running a 100 shot or whatever, the TR6’s will still be fine. Not to mention it will idle/drive better off the bottle which is what you'll be doing 99% of the time.
Old Apr 14, 2010 | 01:55 PM
camscam02's Avatar
Yes you can get away with the tr6s in that range, but the better plug is a non projected plug without a doubt. you can get them in heat range 6,7,8 etc. Most of the time you will not notice one difference in idle and driveability even if you put an 8 non projected plug in it. Try it before you deny it.
Old Apr 18, 2010 | 09:58 AM
2001 Red Coupe Bandit's Avatar
br7ef
