How much can a Walbro 255 handle?
Old Apr 17, 2010 | 07:38 PM
LS2Monte's Avatar
Default How much can a Walbro 255 handle?
I'm running a stock long block LQ4 with a Comp 216/226 cam, long tubes, EFI victor Jr, 42lb injectors, and a 1000cfm TB. Best pass to date with the carb was 12.05 @112. I'm shooting for 11.80's NA with the EFI and plan to hit it with a 125-175HP plate kit.
My fuel system consists of a intank Walbro 255 (with a hot wire kit), and a -06AN feed.
Will my current fuel system support a 150hp setup? How about a 175 hit? I plan on running a seperate regulator for the nitrous fuel solenoid.
How far have guys pushed a single Walbro 255?
Old Apr 18, 2010 | 12:03 PM
nickp's Avatar
the 255 on my lt1 starts to lean out on anything over a 150 wet shot.
Old Apr 18, 2010 | 04:28 PM
BADMOON's Avatar
Do a stand alone. Yea you may have to pay 5-10 bucks a gallon for race gas but its the safest way. As long as you intank will support the motor your good to go. Judging by your #'s it will
Old Apr 19, 2010 | 07:29 PM
LS2Monte's Avatar
By your last line, are you saying it should be OK as is?
I'm thinking about running dual intank walbro's, -08an up the car, and a 2nd regulator for the nitrous side. I have everything but the 2nd pump and the time....
But what have people run on a single Walbro?
Old Apr 21, 2010 | 10:08 PM
conde'strans's Avatar
I would like to know as well! Can a single intank Walbro 255 handle a 175-200?
LS2Monte- I also have 42lb injectors and in the same situation as you!
Old Apr 21, 2010 | 10:21 PM
BADMOON's Avatar
I am gonna go with no. If sprayin that much I would go with twins or Aero 1000 if on pump gas. Or like I said before run race gas to be safe through a stand alone. But hey its your guys motor I dont know how much power you are pushing NA. I will say my 255 is maxed out on motor .
Old Apr 21, 2010 | 10:42 PM
383LQ4SS's Avatar
Single 255lph walbro intank, hotwire kit and voltage blaster got me 700-725 rwhp without issue for three years straight. Pump was still good when I parted out the car. Voltage blaster was the cheap one you get from Speed Inc...like $100. Boosts voltage to the entire car at WOT. I also used 42 lb green tops. I was around 99% DS
FYI this was a 385 ci motor making about 425 on motor and a 300 shot all dry
Old Apr 21, 2010 | 11:27 PM
dnkynrbk's Avatar
You probally safe on a 15O shot I did that with my old kit. The thing is I would worry about leaning out one side of the motor with it draining from the fuel rail with a 200. I would call nitrous outlet or Hsw and talk to a tech
Old Apr 22, 2010 | 09:04 AM
JoeyGC5's Avatar
I did 612hp/592tq on a forged 346 with a tnt 175 shot and no boosta pump, using a racetronix 255 and hotwire kit. After that I went to a stand-a-lone and now make 548hp on motor (same racetronix) and 754hp with a Nitro Dave single nozzle 200 shot.
