What to set my window switch at ?
I had my tuner set my factory rev limiter (fuel cutout) at 7000
I have my shift light set at 6400 and with my slow shifting and spraying the juice I am thinking I will be shifting at about 6700 since the light is coming in at 6400
IS it safe to set the window switch at 2500 to say what 6800 ? In this M6 car?
Is there much danger in going below 3000 ie... setting the lower edge of the rpm window at 2500 RPM ?
We did just get a 131 HP gain on a 150 shot with a great knock count, so I am pumped.
This is my DD and it will only see the track once or twice this year, it will mostly be getting sprayed on the street with my ET streets. (Yes, I do live in the middle of know where)
TIA, Zach
I wanted a setup where I simply had to turn the system on and then hit the pedal. The controller does all the rest. The window switch ensures nitrous is activated within an appropriate range and the WOT switch is a "safety valve" in the event I need to back off of it (for whatever reason).
If you have a street setup and want a little help with traction, I'd highly recommend the progressive controller setup. I start at 80% on at 3200 rpm and it ramps to the full 100% hit by 4000. Works wonders for traction on the streets. I imagine the drivetrain appreciates the reduces shock of the hit as well.
