My cam choice with a big shot???
Old May 4, 2010 | 12:18 PM
Irby's Avatar
Restricted User
Default My cam choice with a big shot???
I was just wanting to know what everyone thinks about my cam choice and setup will do with a healthy shot of N2O. (300 shot)
Cam-252/258 641/652 on a 110 lsa
WCCH 245cc heads
408 iron block
Vic jr intake
th400 4K stall
fab 9"
F-body 3300lbs
I know the cam will be great N/A but I just need more input on the nitrous side.
Old May 4, 2010 | 12:45 PM
ATVracr's Avatar
Wider split and more lsa.
248/264 on a 115 something like that.
Old May 4, 2010 | 12:49 PM
jmill96Z's Avatar
You think the 115 will work with the vic jr? Reason asking is that my cam was a 112+4, and I lost the whole bottom range of torque with that LSA. Mine is a stock cube car, does that make it apples and oranges?
Old May 4, 2010 | 01:27 PM
ATVracr's Avatar
Gonna lose torque with a vic jr. but thats whats the N20 is for.
And yes the extra 60 cubes helps make some more torque.
Not saying you coundnt use a 112 lsa but it doesnt seem like a "ALL OUT" nitrous cam with that lsa.
Old May 5, 2010 | 11:41 AM
Noyzee's Avatar
8 second mod
i would install that cam atleast 2* advanced im guessing its recomended to be in at 110 i would install at 107 or 108.
Old May 5, 2010 | 01:36 PM
Irby's Avatar
Restricted User
Really? But other that that you like it? I've been getting many mixed opinions about this cam.
Old May 5, 2010 | 01:37 PM
Irby's Avatar
Restricted User
I also forgot to mention this is solid roller
Old May 5, 2010 | 01:42 PM
ATVracr's Avatar
107 or 108 for nitrous?
Maybe that why my **** is slow.
Old May 5, 2010 | 01:52 PM
jmill96Z's Avatar
Wait a minute.....We need to discuss this. I'm getting a new cam this year, along with some other upgrades, and I've been told by a few fairly reputable people to look at 108-110. Help me out here Wayne
Old May 5, 2010 | 03:00 PM
ATVracr's Avatar
Dunno, I am no cam guru but every cam in my car for the last 5 years has been 115 or 116.
Like I said maybe I'm wrong.
We started last year with a 28x/29x 87x/91x .... 116 (yes 900 lift)
Went to a smaller cam mid season and picked up a little but that one was a 116 also.
Seems like a 108 would be good for a all motor and small shots to me.
Alot depends on RPM, heads, intake, exhaust, amount of N20.
Old May 5, 2010 | 03:50 PM
kinglt-1's Avatar
I agree with atv, if you want a cam that is taylored for the jug, get a wide lsa such as a 115 or 116... Check out thunder racing, all of thier power adder cams are spec'd on a 115-117 lsa range.
Old May 5, 2010 | 04:01 PM
Irby's Avatar
Restricted User
All the cams that I saw on thunder racing that say anything about "works well with nitrous" are 110 to 112
Old May 5, 2010 | 04:18 PM
kinglt-1's Avatar
yes about any cam will work well with nitrous up to about a 200shot. When you get a cam specd specifically for spray the lsa is generally 114+. Atv is spraying 350+ running low 5's in the 1/8, So Id say he has a clue. If you dont want to sacrafice power off the bottle then go with a 110-112 lsa. But if you plan on spraying over 200 the lower lsa cams won't be as "efficient" per say.
Old May 5, 2010 | 04:35 PM
Irby's Avatar
Restricted User
Got ya. Well I guess this cam will do for now. I'll prob get a more nitrous specific cam cut next season.
Old May 6, 2010 | 12:25 AM
LilJayV10's Avatar
Really?
That's freaking insane.
I am going to take my little 150 shot car home.
Old May 6, 2010 | 08:02 AM
ATVracr's Avatar
Really?
That cam was a little much for our lil 396 thats why it picked up with a smaller cam. (wasnt a whole lot smaller but enough to make a difference)
Now with this big motor we are building I'm thinkin the cam will be a little bigger than either one of those.
Old May 6, 2010 | 08:47 AM
Fireball's Avatar
real men have a full inch of lift
Old May 6, 2010 | 09:04 AM
ATVracr's Avatar
I think Cary mentioned something about an inch of lift for the new cam.
Man up !!!
Old May 6, 2010 | 01:08 PM
Noyzee's Avatar
8 second mod
i ran a 110 in my 427 solid roller. 73x, i installed at coms recomended 110. i then advanced it and instaled at 107.5 and picked up over a tenth on motor and lost nothing on spray. that was with a 200 shot. to me a 300 shot is a mild spray set up. 200 is small and 150 is baby so imo a tight lsa is better on a mild shot. if your spraying big and want all the power on spray only then a wide lsa is a bit safer, i dont think its going to be as fast tho.
the cam itself isnt something i would spec, but its not bad. i would normaly go with 9-12 degree diff so say 248/258 to rid some heat, but with the right tune up this cam will make power.
like i said tho ive always advanced my cams, i have been around small and big blocks a long time and i know a lot of guys who build fast ones and little tricks like advancing a cam is something not many did or do with ls1's because so and so says not to. i do it and it seems to work. i will be going to the track tomorrow with a pretty much cam only motor in my white car, we shall see how she runs. very mild cam. 227/235 on a 112+4 and its installed advanced an extra 1.5 degrees
all these cams you can by are mostly tested on the dyno and make power on the dyno, a lot of them are not the best for the track. i always custom grind my own cams. im not a shelf cam guy. ive tried it and found my customs are smaller and run faster track times
Old May 6, 2010 | 01:09 PM
Noyzee's Avatar
8 second mod
ps, im not pro and im not the fastest, i only know what i know and what i have seen with my own eyes
