Timing mark on the plug
Where is the timing mark? Close to the threads right?
Here's cylinder 8:
I know I'm supposed to tune for the leanest cylinder, but I was curious, is this a nitrous delivery problem, or do I simply just take out another deg of timing?
I have 8deg of retard at the moment.
The fueling you can't tell anything by looking at the top of the plug. The WOT fuel ring is at the base of the porcelon. You will need a scope or cut the threads off the plug to accurately get your fueling right.
and yes it is dead rich or you have an oil problem, I cant tell well because of the pics, cut off the threads so we can see the porcelain to see how rich it really is.
What were you jets? total timing on motor? total timing on nitrous?
also remember when you are leaning it out you will need to watch timing and possibly take some more out.
Timing is 26deg on motor, 18 on nitrous.
Don't add timing until you get the fuel right and watch it as you are taking away fuel.
This is how I would go about it IMO.
Thanks for the suggestions.
I'm curious to know this as well. Thanks
Listen to this guy, he speaks the truth.
When looking at the timing mark look at the strap with a magnified light. Once you see the timing mark take your thumb and wipe the strap clean down to the metal just to varify the mark you see is still the same. The burn mark on the strap metal is the most acurate as it gives the best detail.
The fuel ring will be at the bottom of the porcylyn like stated above but I still look at the smooth base where the pstrap is welded to and the top range of the porcylyn as I am dialing it in. (I dont feel like cutting plugs up until I am close on the tune up) On the smooth base I look for a full color change. Basically a charcoal gray. On the porcyln I use a magnified light just to varify I do not see and signs of pre detonation or fuel spots.
If there are silver specs on the porcyln its a sign of pre detonation. If there are black spots its fuel and odds are the smooth base is a black color shopwing to rich.
Once I get these areas along with timing and heat range locked in then I will start cuting threads to look at the fuel ring.
Dave
Dave
