Big Ups to HSW/First Time at Track.
get a radial, and be a lil more aggressive with the clutch.. times will fall like bricks off a roof.. First pass: I did burn out, launched, spun,peddel stuck to floor, shifted to 2nd, stopped spining, nitrous hit and started spining again. Let off and ran a 18.00. Big Fail!! Let air out M/T DRs
2nd pass: Ok burnout, but clutch smells tells me it didn't like it!! Clutch peddle feels soft, feathered it on the start, no juice. took as sec on the limiter b/c clutch didn't want to shift in 3rd= mid 14s, Let air out to about 16lbs.
Finall pass: Left very soft(2.25 60ft), shot hit hard in 2nd at 3,00 RPM, tires held, car shifted into 3rd with small hesitation= 13.06 @ 105.09MPH
P.S.Forgot to thank all ya'll in the nitrous section for all the advice and confidence to spray!
My name is Brian, and I am a nitrous addict!!!!!
Take a look at the monster clutches, I put a stage 3 in mine and it takes a beating on the bottle like nobody's business. Also, get a Tick adjustable master cylinder!!!! It will cure that sticky pedal, and give your clutch that perfect pedal feel. Some sponsers on here will do a package deal
