how are you mounting your nozzles??
Old Jun 3, 2010 | 06:49 PM
ls1curt's Avatar
Default how are you mounting your nozzles??
hey guys, looks like ill be gettin the Z tuned on monday, so i wanna get my nitrous setup all hooked up. i was running a fogger nozzle in the bellows, but i switched sides now and with the retaining nnut, the tip of the fogger is just barly sticking out. where are you guys putting your nozzles at? btw i had it in the end of the maf but then i cant run my smooth bellows.
thanks
Old Jun 3, 2010 | 07:30 PM
ls1curt's Avatar
does this look okay? or should the nozzle be more towards the center?
Old Jun 3, 2010 | 07:31 PM
02TransAm/Batmobile's Avatar
I never found a neat way of mounting nozzles until I checked out Harris Speed Works solenoid brackets. I purchased this one:
http://www.harrisspeedworks.com/prod...&cat=55&page=1
They have different ones so you'll have to check those out as well.
Old Jun 3, 2010 | 07:40 PM
Oh shoot, my bad. I was thinking you were asking "how to mount the solenoids."
Old Jun 4, 2010 | 02:49 PM
Chris@NitroDaves
Guest
Posts: n/a
That location looks just fine.
Old Jun 4, 2010 | 05:36 PM
ls1curt's Avatar
okay sweet, looks like ill be running it like that then. thanks
Old Jun 8, 2010 | 03:15 PM
Chris@NitroDaves
Guest
Posts: n/a
Your welcome
Old Jun 9, 2010 | 03:59 PM
Brian Coles's Avatar
That is how my post MAF dry nozzle is mounted. Seems to work well. Hits much harder than when I had if mounted in lid.
