Will unleaded fuel show clear fuel ring on plug
Made some 200 shot runs yesterday on new plugs. Engine was cut off after the run each time. Could not see any fuel ring on the ceramic when I cut the threads off. The strap looked about right for timing. Also ran my FJO serial wideband at the same time so I could make a comparison. Fuel was increased untill AFR was 11.60 - 11.70 and plugs stayed clear white. The fuel I'm using is VP 109 racing unleaded. Plugs are #8 NGK's and timing was at 19*. Are these results normal for unleaded fuel?
I have had to make 2 or 3 passes with a new set plugs then towed to pitts then change the plug and cut it. This is after you get it in the ball park first. That way there is a good line on the porcelin.
Attached are pics of typical plugs with 4-5 passes and lots of idling and one showing just one pass on a new plug and no idling.
