nitrous newbie
Old Jun 10, 2010 | 01:42 PM
1nasty86's Avatar
Turd Gen Guy
Default nitrous newbie
ok im wanting to have ut where i can run a n/a tune and a nitrous tune but plan on having my car fully tuned by my tuner. question is can i use the microedge to run these two separate tunes or do i need something else.
Old Jun 10, 2010 | 02:06 PM
89ROC-Z's Avatar
Being as i got a sbc with dizzy i used an ignition box that pulls timing when the noids are activated.
For an coil on plug i "think" the interface will do that for you. Get the interface and microede from hsw and you'd be set.
Old Jun 10, 2010 | 02:34 PM
Nick@HSW's Avatar
What are motor is this going on? Are you looking for a device that allows you to run max N/A timing and pull timing when the nitrous is activated? If so, you'll want the Interface controller. MicroEDGE is a window switch, tps switch, a/f shut down, dual stage controller with built in gear lockouts and delays.
Nick
Old Jun 10, 2010 | 03:07 PM
1nasty86's Avatar
Turd Gen Guy
Nick
yes its going on a 5.3 and yes i want to run my current tune and have a separate tune for spray
Old Jun 10, 2010 | 04:12 PM
Nick@HSW's Avatar
The Interface will pull timing for you and if you're still running a maf based tune, you can add fuel for a dry shot as well.
Nick
