C5 zo6 tach signal wire location
Old 06-21-2010, 12:49 PM
zactaylorss's Avatar
Exclamation C5 zo6 tach signal wire location
Can someone please give me info on where to find the tach signal wire for an msd window switch on a 2002 z06?
Old 06-21-2010, 01:23 PM
LS1TECH Sponsor
Grant@NitroDaves's Avatar
At the coil connector, should be Pin C White wire(large coil connector, 1 on each valve cover) (color may vary but will be the same pin)
At the pcm, Pin 10 Blue wire.
Old 06-21-2010, 02:25 PM
Thankyou if I pull the signal from the connector on the passengers side does the box need to be in 4 or 8 cylinder mode
Old 06-21-2010, 10:57 PM
03EBZ06's Avatar
I just installed a Raptor shift light. I have a 2002 Z06. The tach signal is
PIN 10, WHITE WIRE. Set it in 4 cylinder mode.
Sorry, confused, about what you are doing with a window switch. I'm guessing you meant tachometer signal wire.
Old 06-22-2010, 02:17 PM
Chris@NitroDaves
Guest
Posts: n/a
1cyl mode i believe
8969 Instructions
http://www.msdignition.com/Products/...ow_Switch.aspx
If it's one of the non digital one i believe you use 4cyl mode
Quick Reply: C5 zo6 tach signal wire location
