Will I be safe running 100-150 shot?
Old Jun 29, 2010 | 11:02 AM
speedfreak391's Avatar
Default Will I be safe running 100-150 shot?
I am trying to figure out what or how much is safe to spray on a 02 5.3. I have a ls6 intake, and I am trying to find a ls6 cam. At what point do I need rods? I am planning on getting a set of arp rod bolts, but rods are out of the picture for me right now.
Old Jun 30, 2010 | 09:45 AM
So nobody can tell me if a 150 shot is safe or not? Rod bolts, rods, pistons? Are they needed?
Old Jun 30, 2010 | 10:17 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Seems like you have a several questions. Give me a call at the shop and I can get you all setup. Will go over your setup, make sure its safe, and get you lined out on parts if you happen to need anything else.
Graham @ NX
Old Jun 30, 2010 | 10:26 AM
dnkynrbk's Avatar
You are safe on a 100 shot that is if you have #7 plugs and have someone that can tune your car and retard your timming
Old Jun 30, 2010 | 05:07 PM
Chris@NitroDaves
Guest
Posts: n/a
You will be fine spraying the 5.3 on 100hp and even 150hp. You will need to make sure that you have the correct plug in there ( BR7EF ), you have enough fueling for the size shot ( If you plan on a cam i'd suggest upgrading the fuel pump ), and finally you need to make sure it's tuned properly.
Old Jun 30, 2010 | 08:57 PM
mikemunoz's Avatar
where can i find BR7EF plugs and how much r they. can i get the at a auto zone or something
Old Jun 30, 2010 | 09:17 PM
los p's Avatar
yes u can get them at autozone and mines where around 22 bucks
Old Jul 1, 2010 | 12:27 AM
Nitro Dave's Nitrous Outlet's Avatar
If you can not find anywhere local that has the plugs we stock them..
http://www.nitrousoutlet.com/catalog...26&section=101
Old Jul 1, 2010 | 10:03 AM
Usually they are pretty easy to get. We have them here at local parts stores. If not Give dave a call. For plugs.
Old Jul 2, 2010 | 09:24 AM
mikemunoz's Avatar
can i have the part number to those plugs, what do they say on the plug? im running tr6 plugs on my car but i hear its a bad idea for a 150 shot y is that?
Old Jul 2, 2010 | 09:29 AM
br7ef is how ngk designates them. Your local parts store can use this number.
Old Jul 2, 2010 | 04:49 PM
Chris@NitroDaves
Guest
Posts: n/a
The best thing would be to tell them you need NGK Stock# 3346 which is the BR7EF
Old Jul 6, 2010 | 06:29 PM
kdavis's Avatar
Are those plugs good for A daily driver that doesn't see alot of spray?
Old Jul 7, 2010 | 11:23 AM
chknhwk01's Avatar
Question helooooooooooooooooooo
yo dave, what is the diffance, be ween br7ef an tr6,s??????????
thanks .......
Old Jul 7, 2010 | 11:49 AM
ATVracr's Avatar
thanks .......
Projected tip vs. a non-projected tip.
In other words a N/A plug(tr6) and a Nitrous plug (br7ef)
let me guess you spray your car with 5,000 shot with TR6's all the time and it runs great.
Old Jul 7, 2010 | 11:53 AM
ryarbrough's Avatar
He and everyone else he knows... I know I've fought that war with him once before.
Old Jul 7, 2010 | 01:59 PM
chknhwk01's Avatar
Cool philly calling.............
thank you..... you ans my quistion, na did it for me, imm going down to,
auto zone, for a set, n20, plug, br7ef... thanks atrracr, thers no war he..
just didn know the ans, now i do................. buk buk buk.. sinba..
Old Jul 7, 2010 | 02:07 PM
brians91formula's Avatar
wtf is wrong with you?
Old Jul 7, 2010 | 02:21 PM
chknhwk01's Avatar
Smile sayyyyyyyyyyyyyyyyy whattttttttttt...
its always the slow azzzzzzz bitchs, that run ther punk mouths an have no
classsssssssssssss..............................
Old Jul 7, 2010 | 02:26 PM
89ROC-Z's Avatar
someone is stoned outa his mind
