TNT Nitrous Install
Old Jul 1, 2010 | 11:52 AM
diablo-Z's Avatar
Originally Posted by 00SS4780
Here's an old pic of mine:
did u trim down the bracket on urs??????
Old Jul 1, 2010 | 11:56 AM
SSmoken's Avatar
where is your bracket not fitting at?
Old Jul 1, 2010 | 11:57 AM
00SS4780's Avatar
If you look closely you can see where I sliced the top of the bracket mounting hole (just the one nearest the tnt ring that mounts on the manifold) to adjust it.
Old Jul 1, 2010 | 12:23 PM
diablo-Z's Avatar
on the side of the intake it doesnt fit right for some reason...i might have to trim mine too
Old Jul 1, 2010 | 12:26 PM
diablo-Z's Avatar
i think i might do the same cuz when i place mine it faces up..its not straight like the way urs looks
Old Jul 1, 2010 | 06:21 PM
00SS4780's Avatar
Thats what was wrong with mine. I just slotted the hole out so I could angle it where I wanted and then just tightened it down. No problems. I'll see if I have a better pic of it.
Old Jul 1, 2010 | 06:47 PM
00SS4780's Avatar
Old Jul 1, 2010 | 10:20 PM
diablo-Z's Avatar
did u run ur fuel line and nitrous line under the throttle body????? how did u tuck it, so it wont rub on anything
Old Jul 3, 2010 | 08:10 PM
00SS4780's Avatar
My fuel line is tucked under but doesn't rub on anything. The nitrous line comes from the passenger side through the firewall. I have it zip tied to the bottom of the air conditioning line.
Old Jul 5, 2010 | 05:13 PM
diablo-Z's Avatar
ok im gna try that se how it goes
