Best way to control difrent functions of a NO2 kit.
Old Jul 4, 2010 | 07:41 PM
beerman985's Avatar
Default Best way to control difrent functions of a NO2 kit.
I'm trying to figur out the best way to control a window switch. 1 gear lock out and wot switch. Any help would greatly appreciative. This isn't. My first time useing just never done a 1st gear lock out. Or window switch.
Old Jul 4, 2010 | 07:55 PM
Beer99C5's Avatar
HSW, Nitrous Outlet, and Dynotune carry units that do all that in one package (Window/WOT/Gear lockouts). Hit their sites and see what you like.
Old Jul 5, 2010 | 10:24 AM
beerman985's Avatar
I looked at there pages and am still lost. Do I need a window swich lock out full thottle and there controler
Old Jul 5, 2010 | 11:25 AM
custm2500's Avatar
Ph.D. in HUBRIS
1st gear is the best place to use the juice. I nearly creamed my self leaving the line on the 100shot! Who cars about trannies and rear ends? They are replaceable.
Old Jul 5, 2010 | 09:58 PM
beerman985's Avatar
me hahaha i only to use the power not wast it on tires
Old Jul 7, 2010 | 05:24 PM
Chris@NitroDaves
Guest
Posts: n/a
Our window switch comes with a built in gear lock out feture that you can activate or leave it deactive and spray out of the hole.
Old Jul 7, 2010 | 07:29 PM
Nick@HSW's Avatar
Take a look at our MicroEDGE controller. It has multi gear lockouts, tps, dual stage, time delays, a file system to quick switch to 3 different saved files on the fly...and you can upgrade it to a progressive controller if you ever needed to for a nominal fee. Its a pretty bad *** unit.
Nick
Old Jul 8, 2010 | 12:10 PM
Nitro Dave's Nitrous Outlet's Avatar
The windowswitch is designed to give you the ability to controll at what RPM the system activates and at what RPM the system deactivates. The TPS feature tells the system when to activate by voltage signal telling it when you are at wide open throttle.
The gear lock out feature works by giving you the ability to delaying the system activation by not letting the system engauge until it has seen the rpm deactivation and then droped in rpm.
Dave
Old Jul 8, 2010 | 01:28 PM
beerman985's Avatar
Nick
I like that controller and all that it does. But am I going to need a window switch also. And I didn’t thank that the ls1 camaro had a tps sensor so how would it tell if it at wot. I have the cheap wot switch that a lot of the companies use. So could I use that and have it complete the series or not
thanks tripp
Old Jul 8, 2010 | 04:24 PM
Chris@NitroDaves
Guest
Posts: n/a
You can use a micro switch without a problem but the LS1 cars do have a TPS sensor.
Old Jul 8, 2010 | 05:17 PM
beerman985's Avatar
ok whats the best way to tap in to the tps. and so i can just use the box thats and nothing eles.
Old Jul 12, 2010 | 08:17 AM
Nick@HSW's Avatar
thanks tripp
Tripp,
It has a dual stage window switch built in. Ditch the wot switch and use the built in TPS switch in the unit. The TPS sensor is located right on the throttle body itself.
Nick
Old Jul 12, 2010 | 05:04 PM
Chris@NitroDaves
Guest
Posts: n/a
What yr vehicle is it?
Old Jul 17, 2010 | 12:07 PM
beerman985's Avatar
99 z28 and i went with the harris contorler
Old Jul 31, 2010 | 10:57 PM
beerman985's Avatar
how does that look..
1st gear lock out.
4.35 tps act
3.90 tps des
min rpms 3000
max 5750
shift 5850
Old Aug 2, 2010 | 08:51 AM
Nick@HSW's Avatar
Looks good. I think that's a great place to mount them on the f-bodies.
nick
