Nitrous wont fire?
the window switch shows red LED when the key is on:check. yellow LED lights when brake is tapped: check. when arming switch is on, Wot switch is hit, and over 3k rpm:no green led on. doesnt fire.
what are the chances the problem is the window switch itself? if it is, how else can isolate any other existing problem? any other ideas? im thinking if the window switch is bad, im gonna get a progressive controller. i kinda want it to work so i dont have to spend any cash.
EDIT: Maybe a sponsor wants to chime in. for help and/or offer me a good price on a progressive controller.....
Nick
EDIT: im guessing i could just replace the relay as they are cheap to see if thats the problem first. then bypass the window switch.
