Nitrous backfire ?'s
Old Jul 24, 2010 | 10:19 PM
1baaadz28's Avatar
Default Nitrous backfire ?'s
OK, i got an 02 m6 with a nos plate kit, runnin 150 shot wet. plugs were tr6's, A/F was 12.8 , bottle pressure was 1100, sprayed fine in 2nd and 3rd and as soon as i hit it in 4th it detonated, any help would be appreciated!
Old Jul 24, 2010 | 10:23 PM
custm2500's Avatar
Ph.D. in HUBRIS
Not enough info.
How was the tune both timing and A/F ratio. What rpm did you drop to when you hit 4th? Gonna take a good deal of info for anyone to know what possibly happened. You have pics?
Old Jul 24, 2010 | 10:48 PM
1baaadz28's Avatar
5 degrees out, hit it at 3200 on a WOT switch, the whole back of the ls6 intake is gone and major cracking all around the intake, no damage to the block, will post pics tomorrow
Old Jul 25, 2010 | 12:36 AM
ATVracr's Avatar
My friends brothers cousin sprays 300 on TR6's I dont know what could have happened.
Old Jul 25, 2010 | 03:23 AM
camscam02's Avatar
Hahaha my great cousin did the same. Weird
Old Jul 25, 2010 | 06:48 AM
jman54002's Avatar
classic^^^^...does anyone read about plugs before they spray?? it seem half the carnage on nitrous motors could be avoided. Sorry to here about the damage.
Old Jul 25, 2010 | 09:33 AM
SargeZ06's Avatar
Shouldn't he be using a 7 or 8 range plug for a 150 shot?
Old Jul 25, 2010 | 10:23 AM
Firehawk441's Avatar
Is this a stock bottom end?
Pump gas?
Old Jul 25, 2010 | 10:46 AM
1baaadz28's Avatar
Yes its a stock bottom end running on 93 octane, on stock pump and injectors
Old Jul 25, 2010 | 11:34 AM
Looking further then the broken intake would be beneficial...
Detonation breaks rings, etc...
Old Jul 25, 2010 | 12:24 PM
1baaadz28's Avatar
motor is comletely apart and nothing noticable,the internals look great. is it possible that i lost the pump and it leaned out?
Old Jul 25, 2010 | 12:34 PM
BOTTLEFEDLS1Z's Avatar
Yes it is possible to lose the fuel pump and go lean, but you'd have more then a intake problem. Piston(s) would be fucked with no fuel and all that heat inside the cylinder
Old Jul 25, 2010 | 12:42 PM
1baaadz28's Avatar
ok im using a zex NMU and could it have not shut off between shifts and had nitrous puddle up in the intake?
Old Jul 25, 2010 | 01:04 PM
You said internals are ok.
Did you melt any ground straps on your plugs?
Old Jul 25, 2010 | 04:23 PM
1baaadz28's Avatar
no Its really weird, nothing melted and the plugs look fine, im thinkin of scapping the whole motor and just doing a wicked 383 and no spray.
Old Jul 25, 2010 | 05:21 PM
BLK02WS6's Avatar
That's what happens when you don't use a window switch... you drug the motor down too far on the shift. A WOT switch alone is not enough on a 6 speed...
Old Jul 25, 2010 | 06:29 PM
custm2500's Avatar
Ph.D. in HUBRIS
This was my guess.
Also still no pictures yet!
Old Jul 25, 2010 | 10:30 PM
89ROC-Z's Avatar
**** the tr6's are waaay too cold! I'd add 6* too
You answered your own question when you said what you have, i mean on what you DON"T
Old Jul 26, 2010 | 05:05 PM
1baaadz28's Avatar
I sprayed the car probably 10-12 times with no issues and the last time I did I had a BIG issue.
Attached Thumbnails Nitrous backfire ?'s-dscn0100.jpg   Nitrous backfire ?'s-dscn0102.jpg   Nitrous backfire ?'s-dscn0103.jpg
Old Jul 26, 2010 | 07:39 PM
SexyTransAm's Avatar
lil super glue will fix that right up
