Whoopass nitrogen push and new intake
Old Jan 22, 2004 | 08:50 PM
383LQ4SS's Avatar
Default Whoopass nitrogen push and new intake
New N2 push with pressure switch...fully automatic
Custom intake. Mandrel bent aluminium 3.5" tubing w/ dual K&N filters.
Another angle
Old Jan 22, 2004 | 09:07 PM
gator's 99TA's Avatar
Al, you feel like building me this nitrous system in the spring? i have already talked to Jeremy about the programing. looks awesome.
Old Jan 22, 2004 | 09:09 PM
slow's Avatar
nice
what kind of pressure switch are you using, ratings on/off
speedshop.org one? i know the nx is set too low, and too broad of a range, on/off.
Very nice setup, as usual
Ryan
Old Jan 22, 2004 | 09:12 PM
VINCE's Avatar
Shorty Director
Wow!!!! You have been busy. Congrats Al!! It looks great..
Old Jan 22, 2004 | 09:16 PM
383LQ4SS's Avatar
Slow,
The pressure switch is from speed shop.org. It has a nice adjustment feature from approx. 600psi to 1500psi. It is quite sensitive and works very well. There is virtually no window. It cycles within about 10psi of the set pressure.
Old Jan 22, 2004 | 09:24 PM
Damian's Avatar
LSX Mechanic
Ahh, you *******
Old Jan 22, 2004 | 11:10 PM
383LQ4SS's Avatar
Someday Josh..but probably not anytime soon!!!
Old Jan 22, 2004 | 11:11 PM
mbaskett's Avatar
Nice setup! Where did you get the solenoid for the nitrogen from and if you don't mind sharing, how much did it set you back?
Thanks!
Old Jan 23, 2004 | 12:05 AM
383LQ4SS's Avatar
The noid in the picture is not the one installed right now. That one didnt work..it would overheat. I eneded up getting that Biondi C02 3000 psi noid thats in Summit for $129. The nitrogen bottle was free from my work. I have a few. All the lines were free from my work The pressure switch from Speedshop.org was like $49 and works GREAT!
Old Jan 23, 2004 | 12:39 AM
Hawkn01's Avatar
Wow !! Thats a sweet air intake set-up. You should consider marketing that ! I bet the aliminum 3.5 manderal bend pipe was pricey.
Old Jan 23, 2004 | 09:16 AM
taqwache's Avatar
looks good man. what happen to your radio, all i see is switches hehe.
Old Jan 23, 2004 | 10:36 AM
RyanJ's Avatar
SSU Moderator
more pics!!! no more 'ready-aim-fire' lights? lol.
I assume both of those lines just go into fan nozzles in the tube? cool.
Old Jan 23, 2004 | 10:41 AM
Big Mike's Avatar
Is it true that the nitrogen push setups are illegal at NHRA Tracks?
Old Jan 23, 2004 | 10:51 AM
383LQ4SS's Avatar
Big Mike. I have never looked in NHRA or IHRA...But I knowm NMRA sais not allowed. I think NHRA is the same.
I made this for convienence on the street mostly. I once raced an 800 rwhp Supra three times in 10 minutes from a roll. If I would have had a bottle heater I would have been done after the first race.
IF you had to race in an NHRA event...you could just arm the system...let the pressure stabilize and then remove the N2 bottle. I used to do this from time to time. It works well as far as getting the exact bottle pressure before a run...but of course doesnt maintain it through the run.
Old Jan 23, 2004 | 11:06 AM
383LQ4SS's Avatar
Yeah...fairly pricey..yes. Brandon has said he would make this on request. But It would have to be worth his time.
$650 to dupe this setup. Thats with 2 K&N filters, the polished stainless radiator support, connectors and clamps, and the 3.5 inch tubing all fabbed up.
Maybe $575 if you want a single filter setup.
Keep in mind you can have NO bumper support for this setup and the crossmember on the intake brace needs to be notched about an inch. You also need to drill twp holes for the intake support mounts.
Old Jan 23, 2004 | 01:43 PM
Vents's Avatar
@ the intake shield!
Old Jan 23, 2004 | 01:51 PM
taqwache's Avatar
did you notice a defference over an aftermarket lid with free ram air mod?
Old Jan 23, 2004 | 01:53 PM
Vents's Avatar
and dude, run the lines under the carpet for cryin out loud!
Old Jan 23, 2004 | 01:58 PM
taqwache's Avatar
man vents, your new job must be pretty easy seeing that you are always on the board all day long.
Old Jan 23, 2004 | 02:00 PM
Vents's Avatar
nope, same job, im just slackin!
