top end spray problems!!
.35 i think
still don't have a pressure gauge, but was more than the other night. I could actually hear the line pressurize when i hit the remote opener
and yep, stock timing
I would also check all your grounds. You could be losing amps as the load increases. I would make sure you are using a 10 or 12 gauge wire for you ground wire.
We had a bad ground on a buddys car one time and was causing issues like this.
What is your timming?
What was the bottle pressure the first of the run and the end?
If you are going to run spray I would find someone in your area to tune your car and have the timming retarded.
It's pretty popular belief that our tachs are pretty inaccurate.
Hell, my car last time at the track was showing almost 6k when it was shifting at 5k (read via HP Tuners). Maybe everythings working right, but the tachs leading you astray...
